LB7: Loping and shaking at idle/NO throttle response
Austinflb7
Aug 24, 2017
I have a 2002 lb7 with 170,000 miles on it. During college I leave my truck at home and it is lucky to get driven once in two to three weeks. The batteries have died probably about three times now and this time after jumping the truck I started it up and it sounded like a hard start at first. It continued to lope and did not change after five minutes. Tried to press the pedal a little to see if it would pick up and the throttle has no effect at all. A "reduced engine power" message came on the message center. Put two new batteries in and did not fix anything. Did not know if it could just be a low voltage issue. Engine shakes bad and sounds like its not running with all cylinders. This is the first time I've started it in three weeks and it ran just fine at that time. What could be the problem? All help is appreciated.
Update:Scanned the truck and got the codes P0380 and P1635. Also found some chewed wires along with some walnuts on the back of a connection that looks like it leads to a sensor. No clue what this sensor is but I have some pictures along with the same connection on an older lb7 of mine so that there is a better view.
tsd_billy
457
oklahoma city
Need to see codes to give you a proper solution to the problem otherwise its just pissing out a window lol. Get your tuner on it and read codes. Im assuming you have something in it idk anyone with a bone stock lb7
Awenta
4,090
CT
Some little critters could've chewed up some wires
Still need codes though
Austinflb7
Aug 24, 2017
six5creed
1,046
58
N.C.
Fuel pressure sensor. Here's a link to all the code #'s on your Duramax http://www.gmc4x4.com/topic/319-2001-2004-gm-lb7-duramax-diagnostic-trouble-codes/
kheims
Oct 7, 2012
85
Also u might want to get a battery tender instead of letting the batteries go dead. Be much better for you. Defiantly fix the wires and keep the batteries from going dead. I know in my truck when I was having a bad battery the truck did some crazy things changed out batteries everything was good again.
JRein
Aircraft Mechanic's Hero
Sep 26, 2015
212
LRAFB, Arkansas
Best repair would be solder and shrink wrap the splice. I avoid butt connectors like the plague. They'll corrode or loosen with time and cause intermittent problems.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Hambone
Always learning
Jan 24, 2016
572
Florida
X2
Also like said battery tender and to add... get some poison so the squirrels and rats leave ya alone.
Or a Mean Tomcat lol
JRein
Sep 26, 2015
212
LRAFB, Arkansas
X2
I also will put bounce fabric softener sheets everywhere when I store a vehicle for any amount of time. I don't know why but rodents hate it
N2BRK
1,907
233
Tub full of green coolant under the hood solved our wire-hungry squirrel problem.
1,615
This is the only proper way to repair modern vehicle wiring. Make sure to keep twisted pairs twisted. Use similar gauge wire, too.
Austinflb7
Aug 24, 2017
The wires were chewed so far back it was unfixable. Was lucky enough to have extra harness laying around. Took old one off and put new one on. Fixed the problem. Thankyou for all the help guys.
