Lobe lift vs valve reliefs
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Let me start off by saying I don't know enough about this topic to know what I'm getting Into.. so I don't want anyone to think Iim trying to prove anyone wrong here. I'm simply making sure I won't run into issues when my engine gets assembled.
I've got a set of 16:1 .020" over oval bowl pistons with no valve reliefs for my build.
I picked up a "stage 1" alternate firing cam as well that states no valve reliefs are needed to run this cam. I got looking at the spec sheet that came with my cam vs what a stock cam measures and it appears this cam has .066" more lift on the intake than a stock cam. I just want to be sure my combination will work together without issue.
Measuring a stock lbz piston to my oval bowl, it appears the oval bowls are roughly .010" shorter from the top of the wrist pin hole to the top of the piston (1.271") and the lbz pistons measures 1.281". I would assume a stock lly piston is the same height wise as the lbz piston..
At how much additional lift over stock are valve reliefs needed?
From what I can tell, I should be good to go..right?
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
lift doesnt necessarily dictate the need for reliefs, the duration and when the valves open and close does. fingers pistons may be decked to simplify in case the block is decked as well.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
Yeah only way to know is get some putty out or a you could put finger light weight springs on and spin the engine by hand. Timing and duration play the biggest part
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Well i have no reason to believe I'll have an issue since I'm sure they have sold hundreds of these cams to guys in my same situation/build. I mainly wanted to learn more about the products I'm putting in my engine.
dirtymax36
2nd place is last
Apr 11, 2013
367
Mike, I have a set of LLY pistons I can measure for you to double check to see if they're the same thickness if you need those measurements.
Fingers
Village Idiot
1,713
84
White Oak, PA
Poor man's clearance check:
Putty the top of your pistons.
Use your old gasket.
Bolt the head to the block.
Lash your valves +0.1
Spin the engine two revolutions.
Check the putty thickness. Keep in mind the putty is 0.1" thicker now than the real clearance.
You can do this with your old pistons to find out your clearance before you order the new ones. Especially important if you are going to get the new ones coated.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Well i already have my oval bowl pistons and i already have my cam. Pistons will not be coated. Empires says no valve reliefs are needed. I'd just hate to have an issue after the short block is assembled. I think im just being paranoid about it.
