I am trying to get more power and I want to do all the "cheap mods" first, is an LBZ/LMM CP3 gonna make a noticable difference on my truck?
i am trying to get more power and i want to do all the "cheap mods" first, is an lbz/lmm cp3 gonna make a noticable difference on my truck?
Ok, my desired and actual are so close now, probably not worth it huh?
It depends on what kind of Pulse width you are running , the better pump might let you command more and still hold rail .
I think my cp3 is failing, anyone have ideas on what to replace it with? Might be the regulator, but I have tried another one and couldn't get it to work. Now at idle I have the pulsing/surgeing which goes away if I turn the lift pump on.
Then leave it on
I would think that the reg would be the cause but if you replaced it already and you find the cp3 to be bad i would def chose the LBZ/LMM pump as the replacement .
