Large Frame Charger Install on LB7
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Gonna be installing my new charger here very soon. I was looking under the hood and in order to fit my 5" intake it looks like the factory coolant line to the turbo that connects at the coolant crossover pipe is gonna be in the way. Has anyone run into this? Will the brass fitting on the crossover pipe get in the way? what can be done about it? Can i cap it off since my new charger will be oil cooled? If so where can a get a cap or plug to resolve this issue?
Thanks
Travis
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Thanks
Travis
Yes travis, I just removed the thermostat, that is the piece it connects to the charger cooling hose, and brazed it shut by cutting it down and brazing it closed. If you need a pic, let me know.
02freighttrain
Team Salad Bartender
Aug 13, 2006
911
sootville, Fl
Travis, the big problem with running a big intake from the stock location to the charger is the "hood Clearance". Here's a photo of a big intake pipe on a GT42. Notice the dent in the top of the pipe to clear the hood. Anyone recognize this engine Bay? Clue, the truck is in Michigan.
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Thanks
Travis
I bypassed the coolant from the turbo as per instructions, you can see them in the DIY section under HTT turbo
how are you getting the oil? from the cam journal or from the oil filter housing?
:nopic:
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Simon,
I was going to use the cam bearing, I was leary at first because of the fear of spinning a cam bearing and ruining the charger, but I install cam bearings all the time at work and you litterly have to hammer those things in. I think that if my cam bearing was going to spin it would have done it by now.
If yall think otherwise i will run an oil line to the oil filter housing.
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
I know who's truck that is :D
SmokeShow
6,818
Lawrenceburg, KY
that pipe is in KY now. ;)
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Has anyone welded the bung hole shut for the coolant and relocated it?
Could I just weld it up and cap off the return line?
Getting closer to install this charger and still up in the air on the obstacle
9,903
149
I would take oil from another place Travis. The valve train needs all the oil it can get IMO. Filter housing with some Simon special braided line would be my first choice!!
As far as clearance issues, Simon does your cowl hood have more clearance than the stocker?? If so, that is an option.
g man
49
That intake above w/ the dent was under a GMC cowl hood. The under hood bracing on the aftermarket hood is the same as stock.;) I think some mods could be done to get a little more clearance and maybe a little less flat spot.
or.....
Do like the ricers and install the turbo "pimple". :D
