LB7: is my oil pressure low?
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
If you mean at warm idle....I think that sounds right, mine stays at the 1/4 mark or a notch above...runs a notch above 60psi in its cruising range when at normal operating temp.
Something that helped with the fluctuation in mine was switching to the JD+50 oil.
MMLMM
Tunergeek
Mar 2, 2008
4,086
42
Reno, NV
www.dyncal.com
I use a digital gauge and it shows oil psi, at hot idle its like 18psi. Its been like that ever since I bought the truck, even before the syn. switch. over.
