2002 lb7 ccsb stock motor LDS 64mm turbo intake and exhaust only changes.
Injectors are going out 316k on them so I don’t feel too bad. Trying to save up for new injectors unfortunantly since the dead turbo took my injector fund I’m a little ways out.
Currently if the temp dips below 30 it’s a bear to start. Always plugged in all night. (Was on a timer) have to pump primer till firm crank motor rinse and repeat 5-10 Times. I usually get two or three false starts then if lucky it’ll start. At times it takes me going wot to get it to start.
Wondering if there is anything I need to look at / add to motor to make her drivable till I can get all my injectors purchased and installed.
I’ve been thinking of getting a lift pump to help not having to pump primer 20 thousand times when attempting to start. Would this help?
