LML Grid heater help
dooitorbust
Jul 23, 2019
Anyone have any troubleshooting info on the intake heater? Truck only has 80,000km on it and and it’s throwing a P154A code for intake heater feedback circuit. Harness looks good and isn’t rubbed. Kinda smells like burnt plastic around the heater. Any help would be appreciated.
dooitorbust
Jul 23, 2019
You should be able to check continuity through it and to ground.
There is continuity between the main power stud and the. Body of the heater. I don’t have a schematic for what each wore on the plug is. I’m assuming black is ground.
And what’s the trick to getting the intake tube off?
clrussell
pro-procrastinator
Sep 23, 2013
5,906
363
Twist the collar on the engine side of the ic tube and then pull. It’s very simple and easy
