Allison 5sp: Gear box or P/S pump?
J_Stone06
Wasn't me...🥴
Oct 13, 2012
347
3
Nowhere, KS
So a couple weeks ago I started noticing a grinding howl coming from the steering. It started just when I turned left and now it's across the entire spectrum. I checked the fluid as a first check and everything was good as a flush was done within 6 months...I haven't really noticed a difference in performance so to speak, it just sounds god awful, especially after the truck has warmed up. Any ideas welcomed. Thanks
Sent from my SM-G950U using Tapatalk
J_Stone06
Wasn't me...🥴
Oct 13, 2012
347
3
Nowhere, KS
Power steering pump.
How would I know if it were the steering box instead? I've tried listening to the area to narrow it down but I can only come up with these two parts. If I replace the pump, is there one you would recommend? I know XDP has one, not sure if it's all that great or not. Also, would you recommend I change out hydroboost to a LML one? I'm looking for a more solid pedal with less fade. I have the typical leaky p/s lines, which have to be replaced. Thanks for the input.
