i just pulled mine out tonight, it croaked in a couple of hrs. Maybe mine is a fluke
i had it wired at the "low" setting, and it was on a hobbs switch to run at 10psi of boostyeah thats really odd. I've never heard of any issue with one of these. How di you have it wired? If you have it wired to run high speed or on a switch (how we did ours) and have it set to high speed, keep in mind, you should only run high speed for a few minutes at a time when needed. Never just sit around idling with the pump running on high. that will burn them up in a heartbeat. The reg we run was about $140, we bought steel fittings instead of using the fancy aluminum high $$$ pieces and shaved some money too. Find a Parker hose store for the fitting and hose.
A Raptor costs 5 bones and has tinny fittings so I would go this way and just put a regulator on. Jegs.com has fittings for a good price considering they'll do a nice job and last with a class look. I just wanted to see the user poll talk on this brand it sounds like a good option. Thanks for the help I'll need to get it this winter in a project. Putting pieces together as they fall in line.
i was on the phone with them on Fri, (fuel lab) and they tried to blame me for cavitating the pump, because i had run a 2 micron diesel filter before the pump, and that i should have run a 75 micron before the pump per their instructions (which was really 7 microns). That would mean that sand would be okay passing through the pump? They then realized that its high flow, and it was okay. I got a rma #, so we'll see how they handle this. FASS or AIRDOG, i have found out, that they have a lifetime warranty.
i ran the pump without a regulator for less than 10 seconds before it blew the plug out of the bottom of the stock fuel filter, i called it quits until i put the fuel psi regulator (the night before the dyno day).Fuel lab has worked great for me
I don't recommend it for everyone but it does has a place in some setups that it will surpass a fass or ad by a long shot!
Vas you ran it without the reg that was prob the reason for it burning up. Sorry you had issues butbit does say in the instructions that it is needed.
The fittings fwiw are orb not a/n and as matt posted you can get for cheap if u don't use race shops for your parts.
Like I said they are not for everyone, fass and ad is plug and play and have done the work for you IMO fl is more for a custom set up. Jmho
yes, a lage CAT filter 2 micron
