Building the front end
Samdweezel05
Jul 21, 2008
860
45
As of right now I have a set of tie rod sleeves. I know there is a kit that comes with all the braces and other cool stuff to build up the front end a little more but I know nothing about it. I am looking for something to let me launch in 4wd and do a pull every now and then. Also wouldn't mind bigger tie rods and ditching the sleeves.
Phil
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
Cognito braces with keep your front end from "toe in" problems up to around 500hp. After that HP mark you should do the straight centerlink from crank it up diesel or Super diesel. The straight centerlink and sleeves will be all you need to launch @ 20psi in 4WD and will keep your tires ointing straight. If you would like prices, send me a P.M. Good luck!
durallymax
Apr 26, 2008
2,756
Under The Hood
I run a crank it up Diesel Centerlink and Upstate diesel SS304 Sleeves.
Somehow I was able to do a 20psi boosted lauch twice. I notieced some wheel hop but the front end was raised up. The second time I blew a half shaft.
The centerlink is a good way to just get it done. But I didnt enjoy driving with it everyday when I had my 35s on. Now with my 265/75R16s it seems ok.
