Hi guys,
Thanks for letting me in to this forum! I'm putting a 2007 VAN LBZ into a 65 C10. The engine is in the chassie and has been
started several times the last year during the chassie build. But now after having the engine out for 6 months, it will not start.
A friend helped me to read out the live data and error codes via the OBD2. It looks like fuel pressure is not building up in the fuel rail. It is on 34psi, not moving at all, not even during crank. When I disconnect the pressure sensor, value go up to 29000psi.
I've done this
1. I have excluded the filter and lift pump. I have a gallon of fuel next to the connectors on engine back side. There is flow in the return line.
2. Disconnected the the CP3 FCA
If the rail pressure sensor is broken, should the engine fire when the FCA is disconnected?
Any suggestions on next thing to test?
Thanks!
/Thomas
I've done this
Thanks!
/Thomas
