  #1
Old 06-05-2016, 10:30 PM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
Default Twins with Twins, Anyone?
Look what someone parked in my driveway today, wonder what he wants mounted in there...
  #2
Old 06-05-2016, 10:32 PM
DefiantArms's Avatar
DefiantArms DefiantArms is offline
Limp Mode Cowboy
Default
nice
__________________
John
2005 Chevy 2500 LLY CCSB "Nyx"
Legal Disclaimer: My comments on this board are based on my personal experiences and life lessons. Don't try this at home. Your mileage may vary. Model shown includes options. Past performance does not reflect actual capability or intelligence. I'm off my meds. Don't listen to a thing I say, you've been warned
  #3
Old 06-05-2016, 10:46 PM
kidturbo's Avatar
Piston Tester
Default
Here is what got evicted.
Nothing like tossing out a perfectly good pair of 900+ hp BBC's in exchange for a pair of smokey old diesels.
Guess I'd better make her smoke pretty good then.
  #4
Old 06-05-2016, 10:52 PM
Limp Mode Cowboy
Default
Some people just have all the money
__________________
John
  #5
Old 06-05-2016, 11:02 PM
kidturbo's Avatar
Piston Tester
Default
It won't be cheap that's for sure. Just the cranks, rods, and pistons equals more than I sold my whole LLY Dmax boat for.. But to have someone come to ya and say "build it right and do it up how you see fit" is a great honor. Only requirement, she be faster than it was with the BBC gassers... That means 105+
  #6
Old 06-05-2016, 11:15 PM
malibu795's Avatar
malibu795 malibu795 is offline
Default
Pair of ~1300hp dmax should do the trick...
LBZ with 68stg 2r with s483? And supporting hard parts?
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #7
Old 06-05-2016, 11:41 PM
kidturbo's Avatar
Piston Tester
Default
What you think about LML block, Callies, Howards, and Fingers rotating assemblies ,LMM heads, 12mm pump, and twin 64mm's side by side feeding them at 4000 R's.
Goal is run DSP5 setups like I had on my boat, but with 600-1100 range settings. What ever they make, they gotta make it all day wide open for at least 1000hrs. I just haven't seen anyone brave enough, or with a dyno capable, ever pin them down at 1300hp and head off to the movies... 900 has always been where I feel comfortable they will survive. Beyond that, I'd have to see someone with a capable engine dyno just drop the hammer and walk away before I try it..
  #8
Old 06-05-2016, 11:52 PM
malibu795's Avatar
Default
Get ahold of Jeremy Wagler.... they have put some 1000hp+ engine in some offshore boats
https://m.facebook.com/WaglerCompeti...82018301843640
http://speedonthewater.com/new-boats...er-at-pri-show
__________________
Adam
  #9
Old 06-06-2016, 12:25 AM
kidturbo's Avatar
Piston Tester
Default
Jeremy hasn't dropped the hammer and went to lunch yet..
I know that boat well, who you think gave them the idea? LOL. She's still long way from being wet. That owner expects 1200 all day long. While I know those engines made well over that for about 5 seconds, I'll be impressed when I see them do 5hrs straight.
To date my old LLY still holds the Dmax boat record with 300+ hrs at 675+hp and still together. Believe it or not, even that power level is much much harder than it sounds.
  #10
Old 06-06-2016, 03:24 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Cool project, most people don't understand the rigors of marine use. We put our equipment thru hell, it takes soon much more to make it right in a boat versus a car or truck. Good luck with it buddy...
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #11
Old 06-06-2016, 04:17 AM
TheBac's Avatar
TheBac TheBac is offline
Default
From reading your past threads, I realize you're probably the guy who will find a way to make it work, but based off what Dmaxes have been put thru in the past, I just dont see how one (let alone two) can hold at that power level for that long a duration even when built with the best parts money can buy now. You're looking at a lot of cubic dollars on a lot of very expensive custom parts to give yourself even a chance to make it work.
We're just not there yet in terms of reliability at the very extremes of high perf. Hope your customer realizes that...
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 [email protected]
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #12
Old 06-06-2016, 06:16 AM
Awenta's Avatar
Awenta Awenta is offline
Default
Let me know where you threw those big blocks out! I'll go clean up.
Hate to say it but a built Cummins platform may be more reliable.
It's going to need some serious cooling that's for damn sure.
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to [email protected]
  #13
Old 06-06-2016, 06:17 AM
malibu795's Avatar
Default
Cool idk that!!!
While I don't have wot experience at in hours I got it in minutes.... with towing... I have has sustained 3/4 throttle for hours, heavy high winds drag
oil temps are biggest issue I see, as it goes nuts faster then any other temp .
Most engine dynos don't have cooling capacity for themselves and the engine for all day long.. unless you access to major OEM dynos
IDK if Wagler deck plate dmax is capable of full water cooled or not. Definitely something I'd look at hard it it was..
I'd be looking at fordged crankshaft. Common 1000hp+ build up with Wagler heads. No one really know for definitely if the AF cams are a fix either....
Gale banks went and increase main journal size on his crankshafts, in short increased material in the area that brakes.. are there for sale to the public ???? IDK couldn't hurt to ask. He's usually pretty active with the public on FB
__________________
Adam
  #14
Old 06-06-2016, 07:38 AM
CaptPhil's Avatar
CaptPhil CaptPhil is offline
Default
oil Temps will be easy to control, unlimited access to cold water helps.
egts will be the biggest hurdle to overcome.
Sent from my SM-G900T using Tapatalk
__________________
2005 CC/SB LLY
Big Dipper w/ 1058
Bullseye Double bat S366
12.05 @ 112mph w/ S366, stock sticks, stock CP3
2005 EC/SB LLY The White Devil
Built Motor
Limitless Diesel Comp Trans
Triple Turbo
Dual Fuelers
100% Injectors (Hahaha Sure they are)
10.67 @ 133mph fuel only
  #15
Old 06-06-2016, 09:15 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
What's considered a comfortable "load" to be on an engine for an extended time? No engine is made for 100% load 100% of the time, that would be grossly over built or overworked wouldn't it?
Next question then is how to make desired hp at said sufficient/safe/normal loading, right? The lower on the load curve the engine can be ran and still make sufficient power, the better chance of this working out with a pair of duramaxes, right? Or am I off in la-la land?
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
