  #1
Old 10-30-2010, 04:45 PM
RPM Motorsports's Avatar
RPM Motorsports RPM Motorsports is offline
smokinum
Default LB7 to LBZ (Wiring)
From what I read, there is not much to it. Please feel free to correct anything I may have wrong below, as this is what I have found so far.
On the C100 connector
Body side "C" (BN) needs moved to "N"
Body side "M" (YE) needs moved to "R"
Body side "G" (TN) needs to be moved to "J"
Add a purple wire to "B" for 6spd tap shift, tap into the pink wire on the steering column
Add a wire to "F" for GM LAN (+)- You'll run this wires to the OBD port "6"
Add a wire to "G" for GM LAN (-)- You'll run this wires to the OBD port "14"
C2(in electrical center AKA under hood fuse block):
Move the Orange wire from F4 to A8
The wire you move on C2 is the TCM power.
On the C2 harness under the fuse box, there are two orange wires that need to be moved to match where they were on the LB7. If not the truck will crank/die about 7-10 times before starting.
The lower rad. hose is diff. LB7/LBZ so I cut the two in the center, inserted a 2" SS tube bead rolled on both ends.
The LBZ Intake Heater grid fuse and fuse holder need to be added to the LB7 as well.
It was a pretty simple swap, and I would do it again over LB7 injectors in the truck anyday, lol. Some more needed PN#s below...
Petal PN#15233970
Petal harness PN#15233968
Shift indexer PN#15866124
Shifter PN#15860125
Small pins Male #15326269/19 Female #12191819/8
Large pins Male #15304731/19 Female #15304719/19
** A 6spd. trans needs to be used, or convert your 5spd. to a 6spd.(TCM, NSBU, Internal harness, Valve body) 6spd tap shifter, 6spd cluster, LBZ throttle petal and petal harness. Am I forgeting anything?
__________________
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #2
Old 10-30-2010, 04:50 PM
DuramaxTireSmoker DuramaxTireSmoker is offline
Default
Subscribing definitely.. Great info.. ya if i ever buy an lb7 and keep having injector issues i may do something like this!! Thank for the info.
__________________
04 LLY
EFI, Trans, Etc.
Sold
  #3
Old 10-31-2010, 12:19 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Thank you for posting this. Henry recently posted the connector diagrams for the C100 in GMSpecs area, too.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #4
Old 10-31-2010, 12:33 PM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
is this consistent for 03-04 LB7 or does it include the 01-02 also??? Just wondering.
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #5
Old 10-31-2010, 09:30 PM
smokinum
Default
Quote:
I found his diagrams for the 03 LB7 http://www.duramaxdiesels.com/forum/...highlight=c100 , and asked him two days ago if he could post the LBZ http://www.duramaxdiesels.com/forum/...528#post404528 . If somebody has a minute to verify that the above (post #1) is true and correct, it would be great.
__________________
(Russ)
  #6
Old 10-31-2010, 11:00 PM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Default
Once I get a better Internet connection driving or at a rest stop on this long boring I 70 I will log in to Gm service info and post the 01-03 to see if there the same.
__________________
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W
Sold but not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
  #7
Old 01-08-2011, 03:38 PM
smokinum
Default
The TCM needs to be powered up as well. On the C2 harness under the fuse box, there are two orange wires that need to be moved to match where they were on the LB7. If not the truck will crank/die about 7-10 times before starting. The lower rad. hose is diff. LB7/LBZ so I cut the two in the center, inserted a 2" SS tube bead rolled on both ends. The LBZ Intake Heater grid fuse and fuse holder need to be added to the LB7 as well. It was a pretty simple swap, and I would do it again over LB7 injectors in the truck anyday, lol. Some more needed PN#s below...
Petal PN#15233970
Shifter PN#15860125
__________________
(Russ)
  #8
Old 01-08-2011, 04:51 PM
Rhall's Avatar
Rhall Rhall is offline
Old Skooler
Default
Quote:
Petal PN#15233970
Shifter PN#15860125
I thought about swapping to lbz stuff this year, but i added it up, and ill probably just keep buying new lb7 injectors. Getting new heads, injectors then sending them to exergy, transmission and some of the other power stuff, injectors will be cheaper. But i will def consider this when i go open driveline. This is a good write up.
__________________
"Caged Hooker"
Tim @ St Joe diesel, Precision Turbos, John @ Floor it Diesel, Johnboy, BT Dieselworks, Banks, Suncoast, Exergy Engineering, Profab Headers, Socal Diesel
  #9
Old 01-09-2011, 12:02 PM
SmokeShow's Avatar
Default
Russ, is the conversion on an 01-02 LB7 truck or 03-04 LB7 truck???
Thanks for sharing!
__________________
Mitch
  #10
Old 01-10-2011, 04:19 AM
chrisuns's Avatar
chrisuns chrisuns is offline
Default
From GMpartsdirect
Petal PN#15233970 $36.85
Petal harness PN#15233968 $38.84
Shift indexer PN#15860124 $56.80
Shifter PN#15860125
$39.03
Fixed the part # on the indexer for you. Also, I added the prices.
__________________
2007 LBZ - Few go fast and handling parts.
  #11
Old 01-10-2011, 04:24 AM
chrisuns's Avatar
Default
Quote:
Thanks for sharing!
03-04 LB7. It's to much of a hassle to transplant an LBZ into an 01-02 truck. The computers talk a different speed and language from one another. You'd pretty much have to change every computer, and rewire a ton of stuff to put a 03-07 engine in to a 01-02. That is why most people don't bother with it. Again it's possible, but way to much headache for what is it worth.
__________________
  #12
Old 01-10-2011, 04:14 PM
Car RamRod's Avatar
Car RamRod Car RamRod is offline
Right Meow!
Default
From what I read, there is not much to it. Please feel free to correct anything I may have wrong below, as this is what I have found so far. What pins are used on the OBD plug for the GM LAN (+)&(-)? I have not looked for that yet.
Those two do not need to be moved, they are unused
or you can use the gray wire that is already there and tap into it near the guage cluster.
I did this swap and figured I'd pass this on.
__________________
2003 Sierra LBZ/6speed Allison
All I can say is SHAM WOW!
  #13
Old 01-10-2011, 08:56 PM
Rhall's Avatar
Old Skooler
Default
Quote:
It depends on what your doing with it, full time puller/racer you wouldnt have to mess with most of the headache.
__________________
"Caged Hooker"
  #14
Old 11-13-2011, 02:28 AM
smokinum
Default
Forgot to add a few pics of the project a long time ago.
__________________
(Russ)
  #15
Old 11-15-2011, 11:57 AM
nekkidhillbilly nekkidhillbilly is offline
FNG
Default
Thanks for sharing!
the lb7 has totally different wiring and bcm ecms etc... to do that swap you would need the complete wiring out of a 03 up truck along with most of its interior electrics to do that
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
