Old 02-26-2020, 09:10 AM
briencolgan briencolgan is offline
brien colgan
Default Hard start when cold?
Good morning all. Iím using starting fluid to get this old thing going most mornings. Even at 30 deg and up. I was wondering if you could take a look at this graph and see what you think. It looks like a bad fuel pressure relief valve or fuel pressure regulator. I know I have a bad injector #4 balance rate is -6.
But I think there are other problems. This started as a cold-weather issue and I thought it was glow plug related so I replaced that relay. But I think the cold weather might just be a coincidence because itís almost 50į here today and still tough to start. It seems to start a little easier in the mornings if itís nosed downhill.
I have attached a video. The first part is just the truck starting and running. And then after a bit I commanded cylinder four on for power balance. Does that command turnoff that injector?
Whether it command it off or adjusts its flow it smooths out the idle.
I also commanded off the FPR which seems
To lengthen that janky actual fuel pressure wave.
I just wanted to get some input from some more seasoned mechanics. I was thinking it was time for a new cp3 because I repaired the fuel pressure relief valve. And replace the fuel pressure regulator. But it could also be that that repair I made is not holding.
https://youtu.be/srRsBxGvrvw
2003 6.6 LBZ stock with spartan supreme service body
Old 02-26-2020, 09:49 AM
2004LB7's Avatar
2004LB7 2004LB7 is online now
I bet its the injectors but wouldn't rule out the regulator either
The relief valve is mechanical only and rarely go bad on the LB7, at least not anything that will effect starting and idle.
Have you done any basics like return rate tests for the injectors or CP3? Check for leaking injectors with glow plugs removed? Etc?
2008 Chevrolet 3500HD DRW LTZ
Old 02-26-2020, 11:47 AM
brien colgan
No havenít run those tests yet. I am planning to later when I get this truck home.
All the injectors are within spec except #4 which is at a -6 on the balance rates.
Old 02-26-2020, 12:14 PM
2004LB7's Avatar
Balance rates wont show anything related to return rates. And with the engine loping like that I wouldn't trust the balance rates either
Maybe just replace the regulator and go from there if it continues
