Old 08-07-2018, 08:23 PM
graystonelbz's Avatar
graystonelbz graystonelbz is offline
Default dome/map lights
I'm sure this is a dumb question, but where is the best place these days to buy LED bulbs. I recently bought a cheap ebay LED interior kit for my LBZ and it has been nothing but problems. Do the 06-07 trucks need the canbus style bulbs to work properly? With the cheap LEDs I was having the issue where the map lights came on at full power when i opened the doors but if I tried operating the maps or rear courtesy lamps interdependently they would be very dim. The cargo light also seems to be wired to the same circuit as the 2 map and courtesy lights? Just wondering what info you guys have because I'd like to have LED in the interior but don't wanna buy more shitty bulbs. And just to clarify I have no issues with any wiring of the truck, Ive had it since new and its only got 40k on it. It hasn't even burnt a original bulb out yet. Thanks in advance.
SSDT DSP 5
MBRP stainless 4 inch
AFE stage 2
Braces & Sleeves
Old 08-07-2018, 10:21 PM
AZlml's Avatar
AZlml AZlml is offline
Diode Dynamics has everything I've ever needed. Multiple brightness choices for every light too.
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
Old 08-08-2018, 05:27 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Or theretrofitsource.com
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
Old 08-08-2018, 06:22 AM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
This is where I go as well.
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Calvert Racing bars
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to:Scott@SDP
Tuned by:Blake@UDT
Best time to date: 12.08 @ 112.58 1.76 60ft
Old 08-08-2018, 09:44 AM
trashygasman's Avatar
trashygasman trashygasman is offline
Slowly but Surely
Superbrightleds.com is where I’ve always gotten mine.
Kyle
2019 2500HD Z71 Custom Sport Edition L5P
(SOLD)2006 White Silverado LBZ, CC/SB 4x4
EFILive by JoshH, MBRP, S&B, Transgo Jr., AirDog 150, ProFab EGR Delete & Downpipe, Limitless Diesel trans kit w/ 1077 converter
2018 3500HD SRW CCLB 4x4
6.0L gasser (company truck)
Old 08-08-2018, 09:52 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
2x
This is what I have. Changed out almost everything to LED. No canbus LEDs. Did need to wire in some resistors for the turn signals though
If you have a Batteries Plus Bulbs Store in your area you may be able to get everything there too. Maybe a little more expensive but wouldn't need to pay any shipping
2008 Chevrolet 3500HD DRW LTZ
Old 08-08-2018, 01:31 PM
So no one with a crew cab has had to wire in any resistors for the map, rear courtesy and cargos to function properly? seems like im the onl one who has had that issue?
SSDT DSP 5
AFE stage 2
Braces & Sleeves
Old 08-09-2018, 05:59 PM
countrycorey's Avatar
countrycorey countrycorey is offline
Trust Me I'm an Engineer
On my 07 classic, my dome light is the original style as it was very dim or wouldn't work. The other lights in the dome lights come on dim until I turn on the map lights.
Sent from my SAMSUNG-SM-G930A using Tapatalk
2007 Chevy Classic CCSB LS 4x4 w/ LBZ & 6 Spd Ally
Graystone Metallic
295/70/17 Nitto Trail Grapplers on Chrome H2s w/ LMM Centers
Custom CamLocker Toolbox
Grizzly Nerf Bars
Pioneer 4100 Head Unit
JL Audio Components
Sportsman Max4 Seat Covers
MPI GT4202/Stock
HSP Coolant Tank
Tinted Windows
MBRP 5"
PCV Rerouted
EGR Blocker & Fingerstick
Nicktane 1 Micron Filter & Adapter
Banks Hot Side Intercooler Tube
ProFab Y-Bridge and 3" Cold Side Boost Tube
AutoMeter Phantom II Boost and EGT on A-Pillar
Hammerhead Armor Replacement Front Bumper
EFILive from IdahoRob
Fleece All On Mod
  #9
Old 08-09-2018, 07:34 PM
Yours does that with Led's or regular bulbs? Mine works normally with the regular bulbs in place, but with Led's I had to keep one regular bulb in either of the map lights, or one regular in the rear individual domes or one in the cargos. I'm hoping this was just an issue of low quality Led's.
SSDT DSP 5
AFE stage 2
Braces & Sleeves
  #10
Old 08-10-2018, 01:28 PM
So I got some very nice bulbs from VLEDs however I am still having the same issue. I can't believe nobody on here has encountered this issue. I gotta believe some of you guys with 2003-2007 classic truck have upgraded to LED's?
SSDT DSP 5
AFE stage 2
Braces & Sleeves
  #11
Old 08-10-2018, 02:26 PM
2004LB7's Avatar
I used LEDs in my 04 LB7 and in my 08 LMM without any problems. Dims as expected.
What wattage leds are you using? I think the lower watt ones may have that issue. I think my dome light is a 5 watt. Not sure about the map lights. Maybe 1 or 2 watts.
  #12
Old 08-10-2018, 02:37 PM
no idea on the wattage, it isn't listed on vleds site. The issue is the same with the cheapest of the cheap ebay kit to probably the most expensive with the Vleds now. All the lights work perfectly fine and normal with regular incandescent bulbs. This is just a super annoying issue. No hacked up wiring in the truck, no blown fuses or anything....head scratching.
SSDT DSP 5
AFE stage 2
Braces & Sleeves
  #13
Old 08-10-2018, 03:06 PM
2004LB7's Avatar
Photos or links to said LED?
  #14
Old 08-10-2018, 04:41 PM
2 of these in the map lights http://www.vleds.com/shop-bulb-numbe...194-14-ll.html
2 of these in the in the rear dome push buttons http://www.vleds.com/shop-bulb-numbe...211-24-ll.html
1 of these in the center dome http://www.vleds.com/shop-bulb-numbe...211-48-ho.html
2 of these for the cargos http://www.vleds.com/shop-bulb-numbe...6-w-5500k.html
SSDT DSP 5
AFE stage 2
Braces & Sleeves
  #15
Columbus450's Avatar
Columbus450 Columbus450 is offline
I got these LED bulbs off of eBay use them for all my dome/map lights inside the LBZ they all work perfectly no issues ,
Just a plug-and-play lightbulb I had issues with one of them for the main map light over head it kept flickering but I just popped another one in and itís been good ever since , Is the bulbs all the way at the bottom of the picture
