  #1
Old 06-28-2019, 03:01 PM
joshuaedmister's Avatar
joshuaedmister joshuaedmister is offline
FNG
Default Going to do the forbidden... Duramax in a dodge
I want to put a Duramax from an 07 1 ton truck into an 06 Dodge ram 2500 megacab, my hemi blew up so I was looking for something more reliable and I have the 1 ton which has a stake body and brake lines, fuel lines, and power steering all busted lines and it's a single cab old work truck, wanting to know if there was a kit or if I would have to fabricate everything, it would be a full blown swap with guages, computer, shift levers but keeping dodge trim, and I have a 3-d printer if I need to make some trim
Sent from my Moto Z (2) using Tapatalk
  #2
Old 06-28-2019, 03:15 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
your starting from scratch here
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #3
Old 06-28-2019, 04:35 PM
cdbright's Avatar
cdbright cdbright is offline
JUST RENT IT
Default
hope you get her done this weekend so we can see how it goes Monday ?
__________________
2016 GMC Denali 2500 4x4 CC/SB LML- 6" Rough Country lift w 20" XDs, EFI, Deleted , 5" straight, 3" DP, S&B
2015 GMC Denali 2500 4X4 CC/SB LML - (STOLEN)
2009 Chev 2500 LMM (TRADED) EFI, all deleted, rode just as hard as her !!!, stayed together
2008 GMC 2500 LMM (SOLD)
EFI,all deleted,rode hard,stayed together
  #4
Old 06-28-2019, 07:17 PM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
It’s only temporary!
Default
You’d have a much easier time swapping in a 5.9 Cummins.
__________________
2010 Silverado 1500 LTZ
Sheer Silver Metallic • Every option except Nav • K&N Intake • EFILive by BlackBear Performance
06 Chevy LBZ
Olympic White • Built Motor/Trans • Bullseye s375 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance
11.76@115.12 SOLD
08 BMW 528xi
Alpine White • Brown Dakota Leather • Premium/Cold/Smoker Pkg • LED AEs • MTec D1S • 50% tint
  #5
Old 06-28-2019, 09:36 PM
weazel's Avatar
weazel weazel is offline
Default
Probably going to have to fab everything up.
I was going to try this years ago, but the dodge I was going to use was a 2000. Couldn’t find any info, so scrapped the idea..
__________________
88 Chevy 1/2 ton- LB7 conversion project
93 Chevy K3500- CR Cummins conversion project
08 Chevy 3500HD- LMM, EFI, Garrett stage 1, 5” exhaust
  #6
Old 06-29-2019, 06:15 AM
TheBac's Avatar
TheBac TheBac is offline
Default
Anything is possible, but this swap would be a lot of work.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #7
Old 06-29-2019, 09:13 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<that’s not me...
Default
6.7 cummins swap IMO would be a much better swap for that truck. If it’s an auto you already have the better auto trans and more room to grow with a 6.7. I’d say it’d be hard to get every5ing to play nicely especially electronics with a duramax swap.
__________________
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #8
Old 06-29-2019, 10:22 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is online now
<<<Future tuna killer
Default
You must have more time than money...
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #9
Old 06-29-2019, 05:26 PM
FNG
Default
I should also mention the donor truck has the 6 speed Allison auto, my dodge has the 5 speed auto, I do realize that a dodge to dodge conversion would be so make so much more sense but I already have the donor Chevy, I would keep the t-case and axles, try to disable abs/ traction control so I don't have that on all of the time and have more fun, I've really always wanted a nice truck with a Duramax but I like the way Dodge trucks look
  #10
Old 06-29-2019, 05:41 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
I say go for it, piss off the Cummins crowd I read about a super duty on comp d that crapped the 6.0. Owner had a 800hp 12 valve installed which ran great but smoked like a... well a p pumped 12 valve Anywho he paid a guy to I stall a 1000hp d-max in place of the 12 valve. Turned out pretty nice and they got all the ford gages to work with the gm stuff iirc. Here’s the thread, good info.
http://www.competitiondiesel.com/for...d.php?t=159558
__________________
Albert
04.5’ CCSB ole blue, built trans, mpi twins, 12.5X @ 108
03’ Reg Cab ZF 6
05’ CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60’
  #11
Old 07-01-2019, 05:35 AM
LCAC_Man LCAC_Man is offline
Gearhead
Default
no reason to disable abs...both chevy and dodge use AAM for axles, the tone rings are the same. I have a Ram3500 front axle in my chevy express conversion and the abs works fine.
Integrating the chevy dash cassette/hvac into the dodge cab would be the toughest part...engine/trans mounts arent that difficult to fab. Getting the cooling stack from a CTD truck would be the easiest for cooling. It would be a huge project.
__________________
Len Barron
2000 Express 155"wb Passenger Hightop
  #12
Old 07-01-2019, 08:11 AM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Default
I think it is awesome to see someone do this! About time some did it!
__________________
06 LBZ "White Lightning" 2wd rclb Stockish Grizzly Locker 3.42 gears Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTLMMStg2 Exergy 12mmcp3 1/8th 7.93@88mph 1/4-12.408@109.18mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
Proud and Honored to be able to say I'm the tuner for some of the Quickest and Fastest Dmax's out there! Stock motor Dmax pass with bolt ons and vgt(JKlennon - 9.802@ 139.53 (5/2/19) Fastest Allison equipped Dmax power truck and first into the 5's with an Allison(Mike Graves Prostreet - 9.068 @ 161.19 (7/16/17)Fastest Crewcab with an Allison(Mike Graves 9.555@149.50(4-22-17) Fastest LLy and Fastest street Truck ever(bcdeutch731 C-10 - 8.395 @ 168.13 (9/22/16) Fastest LMM ever(Harbin_22 - 10.12 @ 138.12 (05/01/18) The #1 and #2 Fastest ZF6 trucks in the world (Ryan Pini LLY ZF6 10.674@132.4mph) #2 is with a stock engine(Jesse Rhodes 10.912@130.27mph)
  #13
Old 07-01-2019, 11:56 AM
FNG
Default
Lol yeah this is going to definitely be a Winter time project but definitely this year, I'm working 80 hour weeks 2 hrs from home right now, I'm just trying to gather as much information as possible, and the HVAC system is my biggest concern, but since I have an entire truck that I know runs and entire wiring harness has been replaced within the last 5 years (thanks Chipmunks) I could do an entire swap of Chevy electronic guts and 3-d print an interior if I had to even temporarily or send off my blueprints for new interior, but I think dodge has alot more room than Chevy imo behind the dash, that's awesome on the axles using same signals
  #14
Old 07-01-2019, 11:57 AM
FNG
Default
But there will be lottsss of pictures
  #15
Old 07-01-2019, 01:51 PM
zakkb787's Avatar
<that’s not me...
Default
Why not standalone harnesses and make a custom auto meter gauge bezel? May honestly be easier. Keep all your factory controls in place.
__________________
Other toys:
2011 Yamaha YFZ450X
2018 GasGas XC300
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
