Old 10-07-2018, 04:26 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default 33-12.50r17 pulling options
Best option for a 33 on a 17 wheel for sled pulling?
Considering the ridge grappler so I could run these wheels other wise also.
I know the truxus sts is probably the best option.
Will be mounted on h2 wheels
03 reg cab. Low and slow
07 crew long classic- stolen
Old 10-07-2018, 05:25 PM
Blackmax123 Blackmax123 is offline
Depends a lot of the dirt around where your pulling. Theirs been so many different variables used that all seem to work well.
Strictly pulling tires or will they see some street use?
Bfg at k/o's do well, the sts's are hard to beat. Some times mud grapplers.
My most recent set I was running 4 faulken wildpeak m/t's in the rear and 2 mudgrapplers up front all in 35x12.5x17.
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- built motor by me, exergy 10mm cp3 swap, danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
Old 10-07-2018, 06:07 PM
2005redlly's Avatar
2005redlly 2005redlly is offline
Gearhead
I have been using general atx. Our tracks are always different. They seem to hook good.
2005- BW FMW S467.7/83/.90 / 100% overs/ppe dual fuelers/ Efi live by DA/ DA trans/ SC1073/ arp headstuds/ bbp traction bars/ DHD lock box/ A.D165/ truetrac/ mishimoto intercooler/ profab manifolds and uppipes /fleece tapshifter
stock turbo/fuel 1/4mile-13.3@103 1.9 60' @7290lbs
Stock cp3 12.01@113.50 1.66 60'
1/8mile 7.37@94 11.58 1.68 60' 117mph
2004 sclb ls. Stock for now sold
1999 rcsb ls- work truck
Old 10-07-2018, 06:58 PM
clrussell's Avatar
pro-procrastinator
Id say our tracks are more hard packed stuff. A few people try super aggressive tires like the mud grapplers and dont have the best of luck normally.
Street use will be minimal, unless someone can convince me that the ridge grappler will do as well all around for pulling as a bfg ko, or sts.
I will say those two are the tire of choice around here for the gas class big boy.
4x4s. That alone says a lot to me, other than a 1000hp big block and a 800hp diesel are two different ball games.
Im just not a huge fan of the ko tires overall. I guess I should have posted the question of ridge grapplers or sts.
We all know sts does very well over all as a pulling tire and shit as a street tire. The ridge grappler is proving to be a legit street tire option, but has anyone used them for pulling?
Old 10-07-2018, 08:04 PM
I started pulling years ago with a set of nitro terra grapplers and they did good.
Not sure how the ridge grapplers will work, but I'd imagine they'll do fine. I like the looks of them. I'll more than likely end up putting a set of them on my lml tow pig this month once my built motor is completed and installed.
I think any new tire with the more sharp edges you can get will do just fine.
Old 10-15-2018, 02:27 PM
RobsDmax's Avatar
RobsDmax RobsDmax is offline
STS and do not ever drive them on the road
2003 Chevy LB7 RC/LB
EFI By Kory
2003 Chevy LB7 CC/SB "Cheap Hooker"
EFI By Kory - S400 HSP Kit - 2.5" Billet Charger - 2.8" Puller
2008 GMC LMM CC/SB
EFI By Kory - Magnaflow Exhaust
Old 10-16-2018, 07:22 AM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
Good all around tire is the General Grabber A/T, the new BFG A/T's don't seem to work as good as the old ones. Don't know anyone using the Ridge grapples's. Generally a all terrain tire with lots of siping works best.
STS are great if you don't plan to drive on asphalt at all.
Mud Grapplers only seem to work good if you have the HP to turn them fast, like 1,200hp +
But these are just my opinions....
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
Old 10-23-2018, 10:07 AM
jdlover1's Avatar
jdlover1 jdlover1 is offline
437 Cubic Inches
i run the exact same setup with STSs. Works good for tracks around here
wade
Puller:04.5 D/A lly 4x4
7.1L w/precision 3.0 built by Burkett Racing Engines
33x12.50r17 truxxus STS on hummer h2 rims
Level V DA Signature Series,1053 convertor
Tuned by Tony @ ridgerunner diesel
'08,'09,'11,'12,'14 northeast pullers asso.,morgan's corner modified diesel pts champ. Thanks Ed Wayne, Guy @ Socal Diesel, Tony @ Ridgerunner,Jeff @ Burkett Racing Engines,Dustin @ Diesel Addiction
The tow rig:2003 lb7.cc/sb 4x4
Dsp5 Tuned,Suncoast stage III with Precision "ML" convertor done by Dustin at Diesel Addiction
  #9
Old 10-24-2018, 12:25 AM
Rancelot211's Avatar
Rancelot211 Rancelot211 is offline
Boyd
Have you seen rbps new all terrains?
2007.5 lmm Ccsb: 628hp 1237tq- sold
New to me 06 lbz ccsb sas. 72mm/s483. 10mm cp3. 60 overs. Bunch of other goodies!
  #10
Old 10-24-2018, 12:27 AM
Boyd
Repulsor mt rx is the name of them. Everyone i know uses the truxus or bfgs.
  #11
Old 12-14-2018, 08:28 AM
Bdsankey Bdsankey is offline
Whats everyone's thoughts on the Tri-Ace Pioneer M/T?
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Billet S475/87/1.00 T4, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans w/DEFEO 6 Pinion Planet, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch Reman Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, Beans Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
