Old 08-01-2018, 03:54 PM
fl0w3n fl0w3n is offline
Gearhead
Default Rear main tool
Iíll be doing a trans swap and clutch install on my LB7 next week.
I plan to do the rear main and slave while Iím there.
Is anyone willing to loan me the tool? I can give a deposit for it.
Also, any other tips and tricks while Iím at it?
2002 LB7/ZF6 CCSB Sierra 4x4
340k miles
Stock...for now
Plans:
KP D60 front, ORD leafs front/rear, Twin Stick NP205, 4.56 gearing locked rear, PSC steering/hydro assist , 37"s on H1 wheels, Titan or Aerotank replacement
SAC45% Injectors, SB SD clutch, Kennedy pump and filter heads, S&B intake, ProFab up/down pipe, manifolds, Mild Tune from Rob
Old 08-01-2018, 04:09 PM
Blackmax123 Blackmax123 is offline
Where are you located?
I have the merchant automotive version.
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
Old 08-01-2018, 05:34 PM
TheBac's Avatar
TheBac TheBac is offline
Moved to Tool Crib.
Good luck.
Tom
Old 08-01-2018, 05:37 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
If it’s not leaking leave it alone. You’re liable to make it worse
17 GMC all terrain L5P, stock with dark windows
07 crew long classic- stolen
Old 08-02-2018, 08:00 AM
Gearhead
I am in Southern California
Originally Posted by TheBac View Post
Moved to Tool Crib.
Good luck.
Thanks!
Originally Posted by clrussell View Post
If itís not leaking leave it alone. Youíre liable to make it worse
I would be fine with that, Iíll try and look closer when Iím in there to see if itís leaking. I would just hate for it to start leaking shortly after I was in there.
Whatís the opportunity to make it worse? I think I remember reading about thereís a cover plate on the rear thatís a pain to line up?
340k miles
Stock...for now
Plans:
Old 08-02-2018, 09:39 AM
BlkMax's Avatar
BlkMax BlkMax is offline
Keep in mind, the flexplate can't just be popped off to take a close look at the rear main seal without buying new torque to yield bolts or some ARP's. To get either the stockers or the ARP's tight will require the flexplate holding tool which goes through the starter hole and indexes in the teeth to hold the flexplate from rotating.
I can't remember the torque value on my ARP's, but I do remember hanging on the torque wrench when I put on my SoCal flex plate.
Black Max....
Black Max, the fun truck:
'03 2500 4x4 CC/LB
Bent Rods, now under construction, its time to put all the saved up parts in....
Special thanks to Pat & Kat McSwain, MikeL, Guy, Trent, and others from here-thank you for the great ideas!
EPR triples
Emma, my DD:
'04 2500 4x4 EC/SB
HTT T4 366 74 .91, 65% SAC's from LDS, Trans Kit from Evan, tunes by Zach at Starlite
Old 08-02-2018, 09:57 AM
clrussell's Avatar
pro-procrastinator
Thanks!
50/50 chance it leaks worse after youíre done if you donít know what youíre doing. I know what Iím doing and donít change them unless itís leaking bad.
Old 08-02-2018, 10:21 AM
Chevy1925's Avatar
you can retorque the stock flex plate bolts 3-4 times before they no long hold the correct torque. Guy did testing on them a few years back with main bolts, flex plate bolts and the stock balancer bolt. certainly aint a bad idea to replace them if you wanted to.
James
best time to date: 12.39
Tailgate Crew Member #4
  #9
Old 08-02-2018, 11:51 AM
Gearhead
Wonít I be changing out the flex plate anyways with the southbend kit I get?
Iím all good for not risking it
The truck has been covered in oil from some other issues but Iíll take a closer peak at the rear main like I said. I donít recall it seeming like it was an issue.
I havenít owned it very long.
340k miles
Stock...for now
Plans:
  #10
Old 08-02-2018, 11:54 AM
Gearhead
Iím the type of guy that likes to do it right to the best of my ability, Iíll typically use only AC Delco unless thereís significant proof that an aftermarket part is superior.
For the $70 or whatever the price is on the bolts, Iíd replace them. Iím already into the trans and clutch for nearly $4500. Not going to skimp on a few bolts.
340k miles
Stock...for now
Plans:
  #11
Old 08-06-2018, 02:32 PM
kaylabryn kaylabryn is offline
FNG
I do know when I did mine I could not get the last 60deg turn on it, it did not matter how big a cheater I got(4') on 3/4" drive breaker bar. This was before mine brain processed the torque to yield and bought new ones. The new ones I got the last 60 deg no problem. Mine could have been re-torqued or over torqued prior to me(got the truck with 200K on the clock).
Mike
  #12
Old 08-06-2018, 03:11 PM
Chevy1925's Avatar
Mike
interesting, bolt must have bottomed out in the bolt hole.
James
  #13
Old 08-27-2018, 06:31 AM
Maridug Maridug is offline
FNG
not that I can think of. I assume whoever is building the motor I think you said Guy is? will be installing the flywheel and front/rear main seals for you, so you wont need that tool.
