  #16
Old 01-04-2009, 12:58 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
Quote:
Originally Posted by Turbo Buick 6 View Post
... I just want to try doing it in public so I don't have to answer the same question 10 times for 10 different people.
Welcome to my world!
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #17
Old 01-04-2009, 04:18 PM
dmax687's Avatar
dmax687 dmax687 is offline
Founder Team TCS...
Default
Quote:
Originally Posted by mytmousemalibu View Post
Ya, i've had to use alot of self-restraint from grabing a floor-jack handle and beatin the tar out of this thing! Call me spoiled but i learned to tig with Lincoln tigs and I love them!
And furthermore, the fully loaded Precision Tig-375Pro with advanced control panel, water-cooled torch, etc. Ya, Ima spoiled sucker for that machine!
I LOVE the precision TIG welders from lincoln. Miller makes nice stuff too. My shop has all miller so I'm kind of use to their MIG and TIG machines and that's all I use all day now. But I used a lincoln TIG back in school and that thing was the nuts!!!
__________________
04.5 lly/ally cc/sb EFI LIVE, Suncoast IV/1056, AirDog 150 t-case brace built by me, s&b intake modified with kodiak LBZ mp custom 4"-5" exhaust by me, dymond eye down pipe, 265/75/16 BFG's on black american racing wheels, DIY egr blocker plate and PCV reroute. Auto meter boost and pyro in the pillar. traction bars and sled hitch by me PPE tie rod ends and steering braces PPE race valve, 06 tow mirrors Delta toolbox
Founder Team TCS
Team Borrowed Time Member #19
ON THE LIST:
-turbo
-CP3 mods
-injectors
* many more mods with more $$
  #18
Old 01-04-2009, 04:49 PM
Turbo Buick 6's Avatar
Turbo Buick 6 Turbo Buick 6 is offline
Default
Quote:
Originally Posted by MAXLLY View Post
Cool, DYI-
So after you get it made and installed who can we take it to to get it reproduced, in Mandrel?
I made it know i want a Pro to make it better? Know what i mean?
Make what?
Quote:
Originally Posted by Lonnie View Post
Hey, guess what happens when you try to do a high frequency start with the ground clamp removed???? It makes the arc from the TIG torch to the metal & through the table back to my arm... shocked the f**k out of me.
I'll remember not to do that again, although it is sort of funny now.
Get used to it, it happens all the time
Quote:
__________________
4.5 CLUB
Member #2
06 2500HD LLY reg cab 4wd
Ever feel like lying, down inside a grave
Listen to the elegy, a buyer of the hate
Ever dance beside the devil, taste the barrel of a gauge,
Ever pull the trigger, the light begins to fade
Feel like slipping away
  #19
Old 01-25-2009, 08:22 PM
Lonnie's Avatar
Lonnie Lonnie is offline
Horsepower Addict
Default
Hey, Turbo Buick 6 what happened to your editorials... I havent seen a new one for weeks?
Here is one for you. Why do my aluminum welds come out so smooth? Not like a stack of dimes, but almost looks like caulking. I can see the edge of the base metal start to melt & then I add the filler & it sort of runs together like solder. Penetration is great. Am I using too much heat or moving too slow? Tried this on 1/8" with 120A & also on 3/16" with 180A. Tried the balanced setting & 80/20 worked a lot better. Reduced the amps, but it still looked about the same, but just took longer to weld. Practicing before I actually need to weld aluminum....
__________________
'82 Chevy Tk. Duramax Conversion - In Progress
http://www.lonniesperformance.com/82chevyduramax.htm
  #20
Old 01-30-2009, 08:00 PM
Default
Been back to work and super busy babysitting Move the torch at a steady speed and dab the wire in and pull it out for every dime. Don't constently feed wire like you would with most ferous metals.
__________________
4.5 CLUB
Member #2
  #21
Old 01-31-2009, 06:58 PM
Lonnie's Avatar
Horsepower Addict
Default
Cool, thanks. That would explain it.
Wondered where you were lately.....
As a general rule, how big should the rod be in relation to the material thickness? Seems like it requires a thicker rod on aluminum than steel.
__________________
  #22
Old 02-01-2009, 10:30 AM
Default
Much of it is personal preferance but I usually use 1/8" wire when welding 1/8" Al. Sometimes I will use 3/32" tho, it depends on what size and type of weld I am looking to produce.
__________________
4.5 CLUB
Member #2
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
