Old 08-13-2019, 01:51 PM
wzschirnt wzschirnt is offline
FNG
Default LONG Cranking time to start
Hi,
2006 LLY. 225k miles. Bone stock.
I had new injectors and fuel head done about a month ago. Before all that, the truck would start after 1 revolution of the starter. Hot, cold, whatever. Now, after sitting a day or 2, it takes 5 seconds, literally, of starter cranking to start engine. When warm, it takes anywhere from 2-3 seconds. NEVER the less than 1 second of the old days. I'm thinking this will result in a starter replacement shortly!! Truck also seems to be "weaker" than before when towing, but may just be my paranoia!!
Took back to garage for testing. Injectors are at about 27k pressure, no codes. Place that did the work says it is normal for "things to change" after this type of work. But, come on(!), this is a bit much!
No leaks visible around fuel head (but sucking air?). It acts like the pressure in the rails is bleeding off when shut down, but I don't know if the system is supposed to 'keep up the pressure'.
Any ideas?
Thanks
walt z.
Old 08-13-2019, 02:13 PM
snowman22's Avatar
snowman22 snowman22 is offline
Does the primer bulb go soft between shutdown and startup? How many times do you need to pump it before it gets rock hard again?
Why did you change all the injectors and filter head in the first place?
2015.5 LML GMC Denali 3500 SRW 4wd CCLB 100k Miles
Mike L Trans, 4" FlowPro, MBRP Down Pipe, 30" FTE Resonator, S&B Intake, Twin Kennedy Pumps, Bilstein 5100, Poly U/LCA Bushings, Kryptonite Tie Rods, EBC Sport Rotors Yellow Pads, Edge CTS2
Old 08-13-2019, 02:26 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Did you replace the cp3? Might be getting weak
09 lmm ccsb ltz, moonshine, mpi s480 over 68mm vgt, sdp y bridge, BigDipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on...Big thanks to BigDipper!
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
Old 08-13-2019, 06:18 PM
FNG
DING DING DING!! Just went and checked primer, soft as a 70 year old guy (don't ask how I know!). Pumped about 6 or more times to get hard, but then I saw it is leaking around where the wires are coming out of the top of the head. I had been smelling fuel when I drove it. Must have put a bad new filter head on.
I guess the shop and I have something to talk about tomorrow!!
Originally did injectors and head because truck threw P0087 code, went into 'limp home mode', had several 'weak' injectors. They were originals. Did filter head because they 'have to move it anyway to get at injectors' and the mileage.
So, we'll see what happens tomorrow.
Thanks,
walt z.
Old 08-13-2019, 08:22 PM
JoshH's Avatar
JoshH JoshH is offline
The primer pump will always be soft after being shut off.
06 Silverado 4x4 CC/SB
Old 08-14-2019, 04:58 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Thanks,
walt z.
It won't be rock hard as it's under vacuum but it shouldn't take a ton of pumps to build pressure. If you see a leak you just found your problem.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Tuned by Starlite
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 08-14-2019, 09:24 AM
FNG
Went to shop this am. They said "yep, that's a problem". New filter head
going on tomorrow and we'll go from there.
walt z.
