Old 05-08-2018, 06:08 PM
Robby Avery's Avatar
Robby Avery Robby Avery is offline
GM TECH @ FENDER GMC
Default Finally bought my first turbo............
I'm the proud owner of a fleece 71.5mm cheetah I bought it used but either way I finally got my dream turbo. I would like to know will the 6 ply ppe silicone couplers be fine for that turbo or should I look else where I'll be on stock fuel for a while thanks
2006 Chevy 2500HD LBZ Duramax Summit White CCSB Tan (neutral) leather LT3 pkg w/sunroof OEM bra 4x4, ISSPRO EV, ATS Twin CP3's, Built Allison, Eaton E-locker front stock G80 rear, Kennedy Twin pump filter combo kit, Snow Perf Stage 2 w/m injection, 4in to 5in banks tip, HM Big K&N, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Rancho RS9000XL, Fabtech HD TR, Cognito P&I Brace kit, DD/Puller/Work Truck
2002 Chevy 2500HD LB7 Duramax Summit White CCSB Grey (neutral) leather LT3 pkg OEM bra 4x4, Kennedy Twin Pump Filter Combo Kit, ISSPRO EV, PPE Boost Valve, DTS Built Allison, MikeL Cooler, ATS Billet Flexplate, DTS 3in DS IC pipe, Bill's 5in CAI (White), Big K&N, 4in to 7in black stack, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Cognito P&I Brace kit, Sleeves, Energy Sway bar Kit, DD/Puller/Work truck
Special Thanks: (David) DTS, (Guy) Socal Diesel, (Nick & crew) DuramaxTuner, (Dan) PPE, (John) Kennedy Diesel, (Tony) All Season
Old 05-17-2018, 10:33 AM
Bdsankey Bdsankey is online now
That turbo will run "OK" on stock fuel but honestly needs more fuel. With some 100s and a 10mm or 12mm it'll be a whole different truck.
The PPE boots are good pieces. Do you have stock piping? If so, may want to look into something that flows a bit better.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch Reman Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, Beans Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 05-17-2018, 11:11 AM
Chevy1925's Avatar
6 plys should be just fine. im running 60psi though them without issue. shit im running 60psi though a factory turbo to intercooler rubber hose
James
best time to date: 12.39
Tailgate Crew Member #4
Old 05-25-2018, 07:06 PM
Thanks James
Old 05-30-2018, 08:49 AM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
I'm still running all the OEM boots lol. In fact the only boot I ever popped was the only non-OEM I have 55psi no problems
-Steve Reno- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
Old 05-30-2018, 05:06 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
I say stay stock boots and spend money on things that will actually fail. Lol...
I agree, they need more fuel, especially to spool worth a crapp...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900 @ 15#'s, BTR top end and boost cam, Trunion upgrade, 90mm, 10% over, 2.8 griptec, 65lb sticks, Mayhem built/tuned.
Old 05-30-2018, 05:09 PM
I'm gonna go the simple route. I plan on a 3in driver side ic pipe upgrade. With supporting boots in place of stock ones. Lml driver side manifold and heat shield. Ppe 3in stainless downpipe and profab tow flows later on. One other question I want to have jet hot coatings done on the turbo what all should be coated? Just the housing or should I have the turbine wheel, vanes, and unison wheel coated to eliminate ever having stiction? Any advise is welcome as this is my first high performance turbo I've ever owned
Old 05-30-2018, 05:12 PM
I have twin cp3s and yes 100 overs will be the upgrade of choice when I can afford them I plan on exergy 100 overs unless there's something better out there
  #9
Old 05-30-2018, 05:14 PM
Personally exergy and S&S are fantastic. S&S is a bunch cheaper.
Also RCD isnít a bad place for injectors.
Current Rides:
  #10
Old 05-30-2018, 05:18 PM
Enlighten me on s and s and rcd please
  #11
Old 05-30-2018, 05:19 PM
The guy who started S&S left exergy. RCD has a very very nice hone/balancing machine so their injectors also come out very nice. RCD is big in the ford game.
Current Rides:
  #12
Old 05-30-2018, 05:27 PM
I thought rcd was the big 6.4 6.7 company you were talking about I want to do there rcd 71mm ihi for the lb7 in my sig later on with 100 overs and twin lbz cp3s as well. Do you have or know s and s website or how to get in touch with them? I really wish some one did the big bang injector process for duramax only aware of it for Cummins.
  #13
Old 05-30-2018, 05:28 PM
S&S only goes through dealers. Lincoln Diesel is a big one of theirs.
Current Rides:
  #14
Old 05-30-2018, 05:33 PM
Better yet how do you like your exergys? Is it your daily driver weekend warrior?
  #15
Old 05-30-2018, 05:34 PM
I daily drove exergy 60s for over a year.
These 250s I havenít driven yet.
Current Rides:
