Old 03-14-2019, 02:18 PM
Shooter56 Shooter56 is offline
FNG
Default 05 LLY spitting coolant out the overflow
So at 216k the LLY is spitting coolant. The upper hose is rock hard. The truck runs fine otherwise. Anyone recommend a place in CT. that does these?
Old 03-14-2019, 03:07 PM
torqued2dmax's Avatar
Call Evan at Limitless , he might be able to recommend someone good !
05 CC/LB DRW LLY Allison
Old 03-14-2019, 06:32 PM
dmax_ty dmax_ty is offline
Sometimes the cap can cause funky issues too. Although, with the LiLLY you may have blown headgaskets.
Try a new cap, just for kicks.
2k18 CC/SB GMC
I have a problem.
Old 03-14-2019, 06:37 PM
FNG
Thanks for the reply, it has been going on for about a month. I tried the cap. Then the thermostat. I'm pretty much figured it's the head gasket. It's going to sit and I'll be driving my 03 gas hd until I decide what to do with it.
Old 03-14-2019, 07:11 PM
Ahh 10-4. Looks like you’ve exhausted all other routes. You honestly would be money ahead to fix it. Especially if it’s clean; 07 and older trucks, hell even LMM trucks are fetching quite the pretty pennies nowadays. Especially if they’re clean.
2k18 CC/SB GMC
I have a problem.
Old 03-14-2019, 08:06 PM
FNG
I got a price of 11k to fix it! One other 6500.00 so it's quite a swing in prices.
Old 03-14-2019, 08:57 PM
slowlml's Avatar
slowlml slowlml is offline
11k is extremely high. 6500 is closer but still a little steep.
Nic
2011 ccsb
Some stuff to make it blow up sooner.
Old 03-14-2019, 09:23 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Both are way too high to me. If you have some mechanical know how and since you have another truck you could do them yourself. I did my lb7 and itís not a terrible job.
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #9
Old 03-14-2019, 09:26 PM
Chevy1925's Avatar
Holy shit! I wish I could charge 11k and get it for a hg job!
Both head gaskets done should be around 4500
James
best time to date: 12.39
Tailgate Crew Member #4
  #10
Old 03-15-2019, 04:31 AM
JoshH's Avatar
JoshH JoshH is offline
Just for reference, we are wrapping up a head gasket job on an LLY right now, and the total comes out to a little under $5500. That's a complete upper gasket set, Mahle grade C head gaskets, ARP studs, water pump, coolant, oil, filter, machine shop charges on having heads checked and gone through, sales tax, and labor.
06 Silverado 4x4 CC/SB
  #11
Old 03-15-2019, 06:54 AM
FNG
Everything is higher in CT. Except my pay.
  #12
Old 03-15-2019, 09:37 AM
11k? Jeezus.
2k18 CC/SB GMC
I have a problem.
  #13
Old 03-15-2019, 09:48 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Where in Connecticut are you?
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #14
Old 03-15-2019, 10:05 AM
FNG
Just got a call from another diesel shop $6900.00 to do the heads. I've called 3 places and got 3 prices now. I probably could do it myself . I've done tons of work in the past on all kinds of engines even rebuilt 6.2 and 6.5 for old vans I had. .
  #15
Old 03-15-2019, 11:39 AM
slowlml's Avatar
I would do it yourself then. All of those quotes are high.
Nic
2011 ccsb
