  #16
Old 11-06-2019, 10:36 AM
bimmer95 bimmer95 is online now
FNG
Originally Posted by juddski88 View Post
From the pics you posted it certainly looks like there's some markings on 1 or more pistons in the wrist pin boss area. Which crank was used? Just curious. There seems to be room for multiple things wrong in this build.
Lb7 crank.im assuming the pistons were matched to weigh the same that's why there's material missing here an there..the rods as well.
Sent from my SAMSUNG-SM-G935A using Tapatalk
  #17
Old 11-06-2019, 08:00 PM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
The marks I'm seeing don't appear man-made. Any marks on the counterweights? Next up is measuring the bore diameter from top to bottom, in 4 quadrants.
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #18
Old 11-07-2019, 11:21 AM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Check the other pistons in the area highlighted in the picture. I suspect that is the true crack origin.
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #19
Old 11-09-2019, 10:58 AM
FNG
Yea well I don't have the tools to measure the bore super accurately right now..mabe I'll get the machine guy to look at it..i can't find any abnormal marks on the crank..this is the counter weight next to the number 5 rod..not going to hit unless the rod is pretty majorly compressed an no marks..
  #20
Old 11-09-2019, 11:02 AM
FNG
I checked all the rest an none of the others are cracked..but o well it won't happen again,I found a great deal on some r&r rod,diamond forged piston assemblys(I know it's overkill but hey u can't be too picky if u want a good bargain) so I'll be boring it 40 over and using those..
  #21
Old 11-09-2019, 01:19 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Your going to DD a forged piston?
09 lmm ccsb ltz, moonshine, mpi s480 over 68mm vgt, sdp y bridge, BigDipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165 w/sump, isspro guages, traction bars, the list goes on...Big thanks to BigDipper!
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #22
Old 11-09-2019, 07:43 PM
FNG
Yea
  #23
Old 11-10-2019, 05:42 AM
Probably not the best idea. Might want to consider a set of the cast oval bowl pistions
  #24
Old 11-10-2019, 06:37 AM
TheBac's Avatar
TheBac TheBac is offline
He may be ok...will just have to be very careful on piston-to-wall clearance.
Tom
  #25
Old 11-10-2019, 01:15 PM
FNG
I'm not convinced that they're as bad as some people make them sound...diamonds have a steel ring land insert which helps some with ring wear..an .007 ptw clearance I think is what they recommend which isn't that bad.an a little racket when they're cold isn't bad to put up with...
  #26
Old 11-10-2019, 02:47 PM
Chevy1925's Avatar
Diamonds will be fine in his truck. Like he said, the steel ring lands they have makes the difference.
James
best time to date: 12.39
Tailgate Crew Member #4
  #27
Old 11-11-2019, 04:10 PM
S Phinney's Avatar
S Phinney S Phinney is offline
Make sure you talk to a Diamond about those pistons before you spend any money. They said they have had some issues with those. Check first!
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
