  #16
Old 08-14-2019, 11:05 AM
Burn Down's Avatar
Originally Posted by Bdsankey View Post
Cat lists them at 850CCA. https://parts.cat.com/en/catcorp/127-0826
Any rough idea on what they set you back?
Around 125
Albert
04.5’ CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, Turbo or Procharged 6.0, 4L80E build inprogress
05’ CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60’
84' Reg Cab SB, 415 BBC, 4-speed, needs a D-max zf6 swap
  #17
Old 08-14-2019, 12:28 PM
Sourdough Sourdough is offline
Alaska Wilderness Wanderer
Thanks everyone. Keep coming with your battery experience.
  #18
Old 08-14-2019, 12:43 PM
fajitatone's Avatar
fajitatone fajitatone is offline
Almost Stock
I have Napa batteries, going on 6 years now. Florida truck, stock batteries lasted 5 years, then I got 2 Optima Yellow tops, those died in 2 years, now on to those NAPA batteries...
2006 GMC Sierra CC/LB 4x4
ONYX Black
LBZ Duramax/Allison.
SLE trim, Line-X.
LT265/75R18 Michelin LTX A/T2 on PYV wheels with 2" spacers/adapters
PPE Airbox Mod * PPE Stage 3 Tie Rods
Allison Deep Pan with Merchant Filter Lock
AirRide Ultimate 5000 bags
Curt 20K 5th wheel hitch
  #19
Old 08-14-2019, 01:05 PM
Blackmax123 Blackmax123 is offline
^^^^^ what he said. I used the napa agm batteries. For what's it's worth they're made in the usa by Deka for napa.
Plus should you have problems on the road there is normally a Napa fairly close.
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- built motor by me, exergy 10mm cp3 swap, danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.----- Traded in..
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
Just purchased- 2007 Chevrolet 2500hd reg cab ls 4x4 lbz/allison 111k miles- future drag/sled puller
2019 GMC Yukon XL Denali ultimate package with 22's.
2015 Vw passat tdi sel premium- sold
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
  #20
Old 08-14-2019, 01:26 PM
OregonDMAX's Avatar
NOT IN OREGON
I like AC Delco batteries, they have treated me good over the years. you can get them off Amazon free shipping if you have prime
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret sheep converter
supporting mods
  #21
Old 08-14-2019, 05:07 PM
PureHybrid's Avatar
Isuzu Shakes IT
Napa batteries here also, make friends with the guys at the store, can get the 800cca for around $90
04 GMC ECSB LLY - Mix breed trans/SC1056 - Kennedy twin pumps/pickup - 531/944
8.17@84mph 1/8mi
Jesse
  #22
Old 08-14-2019, 05:29 PM
Originally Posted by BlkMax View Post
I have had pretty good luck with the batteries from Batteries Plus, both the Duracell and the x2Power Premium AGM batteries.
$820.00 plus core for two of those. Sadly not in my budget. But they have 1,150 CCA that's some serious cranking.
  #23
Old 08-14-2019, 05:42 PM
LB7 Lover 1994's Avatar
LB7 Lover 1994 LB7 Lover 1994 is offline
Know Nothing
GOOD LORD!!! For two pickup batteries?? That’s ridiculous! Hahah not in my budget either!
Hunter
Current ride : 2007 CC/SB LBZ Sierra SLT
Mods are as follows:
Tuned and dyno’d by Mark Broviak at Danville Perf.
4” Wehrli Custom Fab intake
3” Wehrli Custom Fab hot and cold side CAC pipes
Wehrli Custom Fab LB7 pass up pipe
Wehrli Custom Fab 3”down pipe
MBRP 5” Straight exhaust
PPE Race Fuel Rail Plug
Airdog II 4G 165GPH
  #24
Old 08-14-2019, 08:30 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
LLY Cult Leader
Just my opinion...but no matter where I lived I would find the closest auto parts store and get their house brand with the good warranty(5+yr). Autozone, Oreilley, Napa, etc. I would not care.
-Steve Reno- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
  #25
Old 08-14-2019, 11:22 PM
The nearest "Anything" is over a hundred miles away....
  #26
Old 08-31-2019, 09:06 PM
MechanicalReign's Avatar
MechanicalReign MechanicalReign is offline
My battery is drained thinking about that drive.
I also had bad luck with interstate. I have also had good experiance with the napa batteries. There all ill buy right now.
  #27
Old 09-01-2019, 03:32 AM
TheBac's Avatar
TheBac TheBac is offline
Moved over to Fluids/Maintenance.
Ive run NAPA batteries for years and years. Never had an issue. Really liked their AGM ones...those lasted me 8 years. When I went to buy new a couple years ago, those were no longer available, so I went with their Legend series. So far, so good.
I bought an Autocraft Platinum AGM for the Cruze after the OEM went south. That seems to be a decent brand too.
I learned a long time ago not to skimp on batteries for vehicles. Suck it up and try to buy the best you can find.
Tom
  #28
Old 09-01-2019, 01:22 PM
sneaky98gt sneaky98gt is offline
Gearhead
One of my co-workers worked as an engineer for an auto battery supplier for over 25 years. Here's a little FYI I've learned from him.
Virtually all auto batteries are made by one of three manufacturers: Johnson Controls, Exide, or East Penn. Johnson Controls and Exide are virtually identical in how they make batteries and where their materials come from (which is US and "global"). I forget the nitty gritty details, but East Penn has some slightly different manufacturing processes, and usually uses all domestic materials. In general, that normally amounts to East Penn batteries being slightly better quality. The recommendation from my coworker is to basically get an East Penn if you can, but don't fret about it if you can't, and don't pay significantly more money for it. In my experience, they're getting harder and harder to find.
This also means that there's no difference between the different store brands. Interstate, Autozone Duralast, Advance Autocraft, O'reilly Superstart, Walmart Everstart, etc. are all the EXACT same battery if Johnson Controls is the manufacturer, or Exide, etc. And in recent years, I've noticed stores having both manufacturers make the same battery. In other words, an Autozone on one side of town having a Johnson Controls Duralast Gold, while a store on the other side of town having one made by Exide.
One other tidbit no one tells you: of batteries with the same CCA, there's no difference at all between the "silver", "gold", "platinum", etc. lines of batteries. They're exactly the same. The extra money you spend on the "premium" battery is simply a longer warranty. The exception of course is an AGM battery, which is made entirely differently. Just how much better they are is difficult to determine.
So, in my opinion, knowing all this narrows the decision making process significantly. If you want the "best" battery, buy an East Penn battery. Otherwise, buy one from your favorite parts store, and decide on silver, gold, etc. based on much warranty you want.
One last note about finding East Penn batteries. Be careful on taking old internet advice regarding where you can buy East Penn batteries from. When I had to buy a couple batteries for my truck last year, lots of places online stated the Napa and certain O'reilly batteries were made by East Penn. After looking at the actual sticker on the battery in my local stores, it turned out that they weren't. So always check the label. In my search last year, I found very few places that actually have East Penn manufactured batteries.
I wound up with Duracell Platinum AGMs. These are (currently) made by East Penn. BatteriesPlus sell these, but I got mine from Sam's Club, which had them for about the same price as I could buy a standard battery from any of the auto stores. I think it was exactly $250 out the door including tax. So that was a no-brainer in my opinion.
I think the Sears batteries were also still East Penn, but I definitely am not buying anything from Sears that I may have to return under warranty at some point...
