  #1
Old 09-16-2018, 01:33 PM
Johnrt Johnrt is offline
FNG
Exclamation 08 lmm limp mode issues
hey guys I am new to this but have been reading a lot of the conversations, I got a 08 lmm 120k miles and have issues with rail pressure with or with out efi tune from Duramax tuner. went back to stock fuel filter, got a bottle test done yesterday, no fuel. have read post about soft lines. When I did the bottle test I noticed the 3/8 line that is next to what looks like a 1/2 line is bent over pretty good, could see as to where that could cause issues. Is this the line that gm did a cut and replace with better fuel line? Is there a way to view balance rates through an autoal?
  #2
Old 09-16-2018, 04:38 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Have you shimmed to relief valve or replaced it with a race plug? Might be causing your low rail problems
__________________
09 lmm ccsb ltz, moonshine, mpi s480 over 68mm vgt, sdp y bridge, BigDipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on...Big thanks to BigDipper!
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #3
Old 09-16-2018, 06:13 PM
FNG
Default
I did the bottle test no fuel from the the relief valve
  #4
Old 09-16-2018, 06:27 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
Do you have a lift pump? What were you using previously as a fuel filter ?
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #5
Old 09-16-2018, 06:34 PM
Default
Quote:
The 3/8 line is the return line, the 1/2 would be the supply line. They are on the driverside back where they come up if that's what you are referring to. Did you try to command fuel rail pressure to see if the relief valve is popping open? Give us more info on the truck. What all do you have done
__________________
  #6
Old 09-16-2018, 07:02 PM
FNG
Default
No lift pump, started having issues towing so went back to stock tune and continued to have issues after awhile after. Was running wix filters as I was going through acdelco ones every 10k or less.
  #7
Old 09-16-2018, 07:53 PM
FNG
Default
Quote:
Truck is stock other than dsp5 tune. While the tune is loaded it will show low power mode, dump the fuel filter but does not go into limp mode. Stock tune will dump a brand new filter and go into limp mode. The rail pressure will drop with wot. But catches back up after shifts. Only 120k on truck, pulling less than 10k most of the towing life.
Sad part is it is doing this not even towing lately. On 3 rd filter in less than 10k miles. I have a data log of 3 12%grade wot pulls. Just not great with
Efi live to break it down effectively
  #8
Old 09-16-2018, 09:13 PM
darkness's Avatar
darkness darkness is offline
Default
Is the truck over heating?
__________________
Rob
2004 2500hd GMC. Mike L. trans, EPR twins. 620hp/1100tq. bought new in June 2004. Sold on 12/28/16 .
2007 classic 2500hd Chevy (Blacula) bought 3/16/18.
Rare parts steering w/DHD brace, egr delete, pcv re-route, BD lift pump, duramaxtuner perfect tow tune.
  #9
Old 09-16-2018, 11:27 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Kink or collapsing fuel line would produce the symptoms you discribed
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm
  #10
Old 09-17-2018, 04:58 PM
FNG
Default
Truck runs a little warm when towing, sounds to be the same as every other lmm of people I know That have one. I will have to crawl back under it and inspect lines.
What is the thoughts on brands of quality lift pumps?
  #11
Old 09-17-2018, 06:15 PM
Blackmax123 Blackmax123 is offline
Default
As stated above, check the fuel lines on top of the drivers valve cover. A lift pump won't help it the supply line is collapsing shut. But I'd hook the hose from the lift pump right up to the metal hard line at the valve cover and remove the factory 1/2" supply.
__________________
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- built motor by me, exergy 10mm cp3 swap, danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
