  #1
Old 07-18-2018, 02:49 PM
boosted4life boosted4life is offline
Gearhead
Default Gauging interest in fully built street truck
I am considering selling my 2006 ccsb 4x4 that has what I believe is a hole/cracked piston. I don't need to sell or necessarily want to, but depending on what I could get for it I would consider it. The truck runs, just has blow by and +10 balance rate on cylinder 3. Here the specs, I'm mostly looking to see what everyone thinks it is worth.
-built engine, lml crank, Carrillo rods, Mahle race cast pistons, wagler cam, arp head & main studs, oversized mhp valves
-built suncoast, all billet, 1053-1
-danville stg2r 72mm/s483 twins
-ppe dual fueler w/ Danville modified lbz pumps
-250% exergy injectors
  #2
Old 07-18-2018, 04:37 PM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Default
Not related to the sell but just curious how much it took before the piston let go? I got the same ones but a lot less fuel and air, supposedly Mahle changed the casting a few years back for the better.
__________________
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #3
Old 07-18-2018, 04:55 PM
Gearhead
Default
These pistons aren't very old so I'm not sure on casting design. They were also cryo treated and coated. I had A LOT of fuel tho with the 250s. I would guess it was making close to 1100hp. If I do keep the truck it's probably getting forged pistons since I don't daily drive the truck anymore.
  #4
Old 07-19-2018, 05:22 AM
Kunz111 Kunz111 is offline
Gearhead
Default
How much are you asking? Miles? Trim package? Pictures?
  #5
Old 07-19-2018, 07:47 AM
Gearhead
Default
I'm mostly gauging interest, I'm not sure what it's worth. It's got 200k on the odometer but all of the performance parts are under 5000 miles. LT CLOTH trim level.
  #6
Old 07-19-2018, 08:07 AM
rcr1978's Avatar
Default
It's a nice truck, 5k on the motor that's really making me question my piston choice Guess I will find out after a while just I didn't want to go the forged route since the truck is going to be used to haul also. I at least went with the LML oil pump and piston squirters hoping that would help.
__________________
  #7
Old 07-19-2018, 08:20 AM
Bdsankey Bdsankey is offline
Default
Quote:
I'm running CP-Carrillo forged pistons. They spec a much tighter piston-to-wall clearance than most forged pistons. CP wanted 0.008 iirc with a +/-0.0005 tolerance.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp R75", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #8
Old 07-19-2018, 08:22 AM
Gearhead
Default
Maybe I'll keep the truck and look into that. Probably wouldn't be a bad idea to pair the Carrillo rods to the pistons.
  #9
Old 07-19-2018, 10:09 AM
Default
It's not a bad idea. Personally there are 2 main sources of supply in terms of getting street-able forged pistons. With what I've seen in terms of reliability claims from CP as well as speaking with a couple others who have them they are a great choice as is Diamond's pistons with a steel ring land. I believe D&J also is making steel ring land forged pistons but I can't remember.
__________________
Current Rides:
Past Rides:
  #10
Old 07-19-2018, 10:51 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Not kicking a guy when he’s down but why wouldn’t you use fingers oval pistons?
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #11
Old 07-19-2018, 11:41 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Quote:
I have the same pistons in my motor without the cryo or coating. I'm running in the neighborhood of 900 to the tire, and I drive it very hard. So far, it is holding up just fine. I have 100% over injectors and dual CP3s. It has been on a 480/364.5 compound setup until I blew the 80 up a couple of weeks ago. Now it has a single 472 still at about the same power. The motor has 15k miles on it over the past year since I installed it in the truck, if not more.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #12
Old 07-19-2018, 11:05 PM
rcr1978's Avatar
Default
That makes me feel better thanks Josh, I've been second guessing my piston decision for a while The diamonds were to new plus the lead time was huge on them and the CP Carrillo ones there really wasn't much info at the time I bought all my shit.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
