  #1
Old 06-29-2018, 05:51 AM
buster4114 buster4114 is offline
FNG
Default Transmission problem
Hello, I am new at this hopefully I'm in the right spot. I have a 2005 GMC with 1000pk transmission. I've been too three different shops over $1,200 and still not fixed. It drives fine for the first maybe 15-20 minutes or more or less. And then you go to slow down it clunks and will not shift. And when you put it in park or move the shifter to neutral. It clunks and the driveshaft looks like moves back and forth. Turn the key off for a few seconds start it back up and it is fine until you drive it again for a little while then it acts up again. Any suggestions would be greatly appreciated thank you.
  #2
Old 06-29-2018, 06:44 AM
Bdsankey Bdsankey is offline
Default
Quote:
Do you have a way to pull codes? If an Allison is doing weird things there is a very high probability it has codes for it, they are crazy smart.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp R75", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #3
Old 06-29-2018, 07:07 AM
FNG
Default
I could take it to autozone
  #4
Old 06-29-2018, 07:48 AM
Burn Down's Avatar
Burn Down Burn Down is online now
Default
You’ll need a better scan tool than what autozone has.
__________________
04.5í CCSB ole blue, built trans, mpi twins
03í Reg Cab ZF 6
05í CCSB ole crappy, built eng, built trans, mpi twins
  #5
Old 06-29-2018, 07:56 AM
FNG
Default
Ok thanks,What kind of scan tool?I will buy one
  #6
Old 06-29-2018, 08:17 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Tech2, EFI live, or an upper end otc/snap on scan tool. these are not cheap...
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #7
Old 06-29-2018, 08:25 AM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Default
This sounds like a job for a real Allison tech honestly. It will be cheaper in the long run. Where are you located?
Sent from my SM-G955U using Tapatalk
__________________
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #8
Old 06-29-2018, 08:34 AM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Quote:
Originally Posted by Burn Down View Post
Youíll need a better scan tool than what autozone has.
You might be surprised. I've got a cheap actron pocket scanner(9145 I think), and it WILL read tcm codes. I know most cheapy's won't, but actron seems to, and all the AZ's I've been to used actron. So you can try it, but if all you get is a p0700 and no other codes, then you need a better scanner.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #9
Old 06-29-2018, 08:41 AM
FNG
Default
I am located in Napoleon Ohio, the first shop I took it to. They said they did some testing on the valve body and everything tested okay so they took the valve body off and soaked it and put it back on charge me over $600. The second shop by took it to a pressure switch and wiring harness. Charge me around 400. The third shop I took it to put a neutral safety switch on it.
  #10
Old 06-29-2018, 09:40 AM
gmac32 gmac32 is offline
Default
You can run it to me but it is a little bit of a drive
__________________
2011 denali gmc 5.5 lift, 35" tires, carillos, cut, coated lml pistons, hot cam 63.5 mm vgt over billet s480, fox shocks, profab manifolds and up pipes, intercooler pipes, 10mm cp3, ported heads, valve springs
  #11
Old 06-29-2018, 09:49 AM
greendury's Avatar
greendury greendury is offline
Default
Could be a wiring issue I sent you a pm
__________________
02 GMC Reg cab lb7 2.6 puller sold
03 GMC Ext cab lb7 WS puller.
03 GMC Crew dually lb7 sold
  #12
Old 06-29-2018, 07:49 PM
duramax on fire's Avatar
duramax on fire duramax on fire is offline
Default
I had issues out of mine. Wouldn't shift right and throwing several codes. Range inhibit lights kept coming on. With a new one by the way. I bumped with my fist the tcm on the radiator connection and it quit instantly . This was 200 miles from home camping. Got it home and unplugged tcm and added dialectical grease never had a problem since. I would start with that.
  #13
Old 06-29-2018, 09:06 PM
LBZ's Avatar
LBZ LBZ is offline
Soaking the vb. Thatís a new one lol.
Thatís how you fix stuff right? Windmill parts at it till it maybe goes lol. Some shops should be shutdown.
I dunno if Danville builds trannyís or not but they are only 4 hrs or so from you. At least they arenít retarded. Limitless is 10 hrs the opposite direction but I guarantee they will sort you out.
  #14
Old 06-30-2018, 04:22 AM
Blackmax123 Blackmax123 is offline
Default
I've had a couple bigger allisons at work have similar issues due to output speed sensors or speed sensor wiring. It I have allison software to read them there.
You need to take it to a legit place though that can read the codes. Thought there were a few decent shops in Ohio I'll have to dig in my memory bank though..lol
__________________
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- built motor by me, exergy 10mm cp3 swap, danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
  #15
Old 06-30-2018, 04:38 AM
Default
I believe Crank it up diesel was up in your neck of the woods. His website seems behind but I'm pretty sure he's still pulling.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
