  #31
Old 04-01-2018, 06:54 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
Originally Posted by OregonDMAX View Post
fit several rv's in a shop with 14' doors dunno what kind of antennas you putting on your rv
I've rigged a few for customers but they were old Prevost busses converted with full slide outs and every emenity you can squeeze into one. They are pretty neat, you would never know what it was going down the road. Antenna wise KVH, XM weather/audio, wifi booster, etc. They are a challenge to rigg bc of top crowning...
  #32
Old 04-02-2018, 08:30 AM
matt78 matt78 is offline
Finally boosted launches
Originally Posted by AZlml View Post
How thick is the concrete?
4 inch,red select dirt pad,one main beam across and 1/2 rebar. Thought about 5 but didnt do it. Also i paid for the dirt pad out of pocket so it was not in the 60k.
2015 ltz 3500. 97 monaco bus. 2016 2500 gassee. 2001 burb.
  #33
Old 04-02-2018, 08:43 AM
Bdsankey Bdsankey is offline
You will be hard pressed to put a lift in a 4" slab, it will spider crack in no-time.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp R75", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #34
Old 04-02-2018, 08:46 AM
Didnt say i was adding a lift. There is a 41 ft monaco bus in there,seems fine.
  #35
Old 04-02-2018, 10:04 AM
joshd472's Avatar
joshd472 joshd472 is offline
All of it cracks eventually. Best the thing to do is put expansion joints around the lift.
  #36
Old 04-02-2018, 11:25 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
For the lift, just cut out an appropriate sized square opening in the slab and pour a suitable isolated footing.
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
