  #1
Old 06-28-2008, 10:53 AM
NelsonDiesel's Avatar
NelsonDiesel NelsonDiesel is offline
Formerly StewieTuned
Default LBZ regulator - EFI Live
What all do i need to do to run an LBZ regulator in my LB7?
Through my searches i have found there are a few tables that need adjustment but i was unable to find which tables those were.
Another question - Is it worth it to run a LBZ regulator over a LB7. Mines shot in my LB7 and i have a brand new LB7 and a brand new LBZ.... Figured i would run the LBZ but just wanted to make sure before i install it with the new injectors.
DirtyDemon/CodeRed is getting some more work done to her this week :-)
__________________
2002 and 2007 Silverado's
PPE Hot+2 Efi Live
  #2
Old 06-28-2008, 03:25 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Ive never really heard if anyone has successfully installed one due to the 90* of the newer regulators?
Some trucks dont even need adjustments for the regulator
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #3
Old 06-28-2008, 03:38 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
No changes, but you must relocate some plumbing to run an LBZ regulator.
I'm getting a few more LB7 regs made up, but they are harder to get and cost $20 more than LBZ ones.
I'm almost tempted to heat one up with a hair dryer and try to bent it straight.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #4
Old 06-28-2008, 06:40 PM
Default
u wanna trade me a modded one?
I will give ya cash and a new LBZ or LB7 regulator :-)
I will be doing the swap on monday hopefully..... Gonna do a lift pump real soon thereafter.
__________________
PPE Hot+2 Efi Live
  #5
Old 06-29-2008, 11:11 AM
Rhall's Avatar
Rhall Rhall is offline
Old Skooler
Default
My truck has an lbz pump down in the valley and still has a lbz regulator on it, i didnt make any plumbing changes, the connection is really hard to hook up tho. Im thinking about changin back out to a modded lb7 regulator tho, on both cp3's
__________________
"Caged Hooker"
Tim @ St Joe diesel, Precision Turbos, John @ Floor it Diesel, Johnboy, BT Dieselworks, Banks, Suncoast, Exergy Engineering, Profab Headers, Socal Diesel
  #6
Old 06-29-2008, 11:32 AM
That's better
Default
Quote:
That might just work or maybe just cut the end off and solder some wires to it? Kinda ghetto but.......
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #7
Old 06-29-2008, 11:51 AM
BIG DIPPER BIG DIPPER is offline
Default
If you plug the regulator in before you bolt the hard line down, you will be fine. There is plenty of room there that nothing touches when you are done. Just be sure to have the other end of the line/ banjo bolt started or you will be taking the line loose and the banjo bolt out again. I have had no problems doing it this way.
  #8
Old 06-29-2008, 12:01 PM
That's better
Default
Quote:
Good to know! Thanks
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #9
Old 07-03-2008, 01:47 PM
Default
didn't unbolt the hard line - i plugged in the connector before i bolted the regulator down. It clacks like crazy at idle. loaned out my tech 2 for 5 minutes - we are now going on 3 hours that it's been gone.... gonna check things out later....
once i get my license for efi i will check things out and mess with them.
First impression-LBZ reg is nice. I gained a lot of power !
Could have been because the old reg would only make 117mpa
Overall it was an easy install no modifications at all.
gonna need to do something with this idle though - she's loud !
__________________
PPE Hot+2 Efi Live
  #10
Old 07-03-2008, 01:55 PM
2500HeavyDuty's Avatar
2500HeavyDuty 2500HeavyDuty is offline
Book 'em, Danno!
Default
mine makes that same noise as yours does. when i log it at idle i get this. http://www.duramaxdiesels.com/forum/...ead.php?t=6299
__________________
theres a new sheriff in town
Team Borrowed Time Member #17
Danny@dieselbombers.com
  #11
Old 07-04-2008, 12:56 PM
Rhall's Avatar
Old Skooler
Default
Quote:
Thats not too bad, i have twin modded lbz pumps with modded lb7 regulators, when i first put them on it would idle at 23k lol it was horrible, you can adjust the voltage under the rail pressure valve current. I just took my whole chart up 15% and it took the rattle out and now it idles around 5k with a slight lope.
__________________
"Caged Hooker"
  #12
Old 07-04-2008, 01:36 PM
Book 'em, Danno!
Default
Quote:
ive herd what happend when u put on lbz pumps on a lbz
its all backwards.
ima give it a try, it stopped raining to im pop in this new tune.
__________________
  #13
Old 07-04-2008, 02:01 PM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
have ya'll logged your rail pressure at idle
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #14
Old 07-04-2008, 02:10 PM
Book 'em, Danno!
Default
Quote:
Ive been workin on mine fo the past 15 minutes. Used to be 9k it idle.
__________________
  #15
Old 07-04-2008, 02:50 PM
Book 'em, Danno!
Default
it also improved my balance rates for my injectors too, #7 used to be at -7 at one pont, but they are all within +/-2.5 now
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
