Old 09-12-2019, 03:46 AM
Duramax710 Duramax710 is online now
FNG
Default Duramax Performance Parts Clean Out
I have parted out several built motor trucks duramax . With that I have tons of very quality parts . Also lots of stock parts . Prices are with no core charge!
Iím located in Fort Wayne In 468181 can ship on buyers dime.
Phone number text me at+12604151861
LBZ/LMM
Built motor complete details below -$8500
Suncoast Stage 5 trans w/ suncoast 1056 converter -$3850
Exergy 45% over Inj - $2800
Exergy 200% over injectors - 2900
Ppe Duel Fueler with lbz pump - $1100
WC Fab Sxe 472 complete kit powder coated candy apple green hot and cold side -$3100
Danville 72r stage 2 r - $2000
Ppe mani and uppipe - $700
Profab log style mani and uppipe - $600
Carillo H style rods with finger oval bowl pistons - $2500
Used Arp headstuds 1 torque-$400
LML
Full egr delete hot and cold side and bridge -$1000
New zone 5 inch -$1200
New TIS 20x12 8x180 Chrome - $1200
8x210 Stock Denali dually wheels Alcoa with tires 20%-$700
8x210 dually wheels steel with centercaps only 4 - $400
Complete lb7 engine running - $2500 good turbo and inj
Stock good turbo -400
30 over Inj - 1k
Bottom end broken crank - 200
Heads- 400
Stage 3 suncoast built trans with dpc converter - $2500
Ficm /ECM /TCM - $250 each
Industrial Injections 100% over Inj - $2500
Ppe Duel fueler with sportsman pump - $1300
Hsp twin turbo setup with stainless 5 blade s475 hot cold side y bridge and coolant tank -$3500
Fully billet and built suncoast trans over 9k from danville Performance with paperwork- $6000
SoCal stage 2 heads - $3500
Billet inj hold downs with arp hardware - $500
Bank cold air intake with scoop -$250
Transfer cases -900 plus core
Rear ends - 500 plus core
2x complete rearends with Eaton tru trac Lockers -$1000 plus core
Lmm black front clip with cooling stack -$1500
Lbz core support with coolers -$500
01-06 doors clean -$250 each
Harness - 200 each
Ecms - 200 each
Tcm - 150 each
Ficms - 250 each
Built Duramax lbz lmm motor. It came out of a lmm truck. Truck was sold stock was reason I took it out. Build has 20k on it and I do have paperwork on parts. This motor is turn key and ready to go
Carrillo rods
Mahle .020 race cast pistons no reliefs
Arp head and main studs
Ppe dampener
Ppe billet flex plate
Mahle upper and lower gasket kit
Grade C head gaskets
Pinned water pump
New oil pump
Custom cut cam
Keyed and balanced crank
Fully dressed no fuel or air
Old 09-12-2019, 06:57 PM
bonomax's Avatar
bonomax bonomax is offline
PM sent
Big Thanks to Mark @ Danville Performance, Bill @ DR Tuning, Caleb @ Blackout Performance, Tyler @ Titus Auto Performance
Old 09-12-2019, 07:26 PM
rmallen30's Avatar
rmallen30 rmallen30 is offline
What’s the history on the lmm 45 overs
2018 2500 L5P BANKS DERRINGER, S&B INTAKE ROUGH COUNTRY 3.5 LIFT AMERICAN FORCE 22s/33Ē NITTOS
14 DIESEL CRUZE FULL DELETE , INTAKE, TUNE
2015 DODGE 2500 DIESEL CREW CAB G56 SBDD CLUTCH ARP'S FLEECE CHEETAH TUNED AND DELETED
2015 VW JETTA TDI FOR SALE 6 SPEED FOR SALE
2015 Audi A3 TDI premium plus, lowered , deleted , full exhaust < wifeís
Old 09-13-2019, 03:22 AM
FNG
Originally Posted by rmallen30 View Post
Whatís the history on the lmm 45 overs
Got them fresh in 2016 from exergy. Have original flow sheets. Truckhad built motor Danville charger dual pumps and the injectors. Have 20k on them.
File Type: jpg B7070E48-6E22-4B8B-B5A3-FE41E390BA5C.jpg (71.6 KB, 21 views)
Old 09-13-2019, 04:05 AM
dirty_max's Avatar
dirty_max dirty_max is offline
specs on the fingers pistons from the lbz/lmm?
2004 chevy lly with a handshaker
Originally Posted by coker6303
My trucks not a whore...she doesn't lift her skirt for just anyone!
But she is a prostitute...she will do anything for money
