  #1
Old 05-15-2019, 07:54 AM
Jacob tomlinson's Avatar
Jacob tomlinson Jacob tomlinson is offline
Dmax
Default Help lb7 grinding
I made a post a little over a year ago and still have not been able to find the source, when i get up over 50mph and i coast and barely press on the throttle i get a loud grinding noise but it isnt all the time and sometimes sounds louder or softer i replaced u-joints, center support bearing, took apart transfer-case. I noticed marks all over the torque converter, also a shop told me they think is is my wheel bearing but not sure how the throttle would make it grind.
http://https://m.youtube.com/watch?v=1Ynn0ysVx1k&t=79s
__________________
2002 GMC Sierra
Mbrp down pipe to 5 Mbrp straight pipe axle dump
Wicked wheel 2 compressor wheel
High flow intake horn
S&B air intake
6 lift
EFI live 5 selector switch
22x14s with 35s
150 air-dog lift pump
  #2
Old 05-15-2019, 08:45 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Hows the angles on your u joints?
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm
  #3
Old 05-15-2019, 08:50 AM
Dmax
Default
What do you mean?
__________________
2002 GMC Sierra
S&B air intake
6 lift
22x14s with 35s
  #4
Old 05-15-2019, 09:36 AM
2004LB7's Avatar
Default
It is possible, I've seen it on mine, that it is just the u joints and their angles that is causing it. From what you described, it doesn't happen under load. But only when you are coasting and give a light throttle. For me this was when I matched the engine rpms with the tires so there was little load/torque on the drive line. If I was coasting and the wheels where turning the engine or if I was accelerating it wouldn't happen.
I first I thought I messed up the front differential gears or destroyed a u joint. But after checking everything out I determined it was my front drive shaft angle of off causing a vibration that sounded a lot like grinding.
And since I see you have a 6" lift I thought I would ask about your angle on the u joints. If the angles are too sever or mismatched it will vibrate and make noise that can be interpreted as grinding.
Just a thought
__________________
  #5
Old 05-15-2019, 09:45 AM
Dmax
Default
Yea i took out the front drive shaft and ran it stoll
Had the grinding sound, how would u check the rear?
__________________
2002 GMC Sierra
S&B air intake
6 lift
22x14s with 35s
  #6
Old 05-15-2019, 12:28 PM
Tothemax's Avatar
Tothemax Tothemax is offline
xgmtech
Default
well from that video i would say its either the drive shaft angle or a broken flex plate. i bet its the angles tho. looks like there is no spacer under your carrier bearing. im sure one is required for the size lift blocks under the springs.
__________________
2017 l5p cc/sb ltz z71 (stormtrooper edition)
06 lbz ec/sb. stock motor, Danville 4094s2r, built trans by me, limitless 1078 converter, 60% sticks, S&S 12mm pump. dyno tuned by mark @ Danville. 775hp 1383ftlb
best so far. 11.440 @ 118.12 1.623 60ft
06 lbz rc/fb dually work truck. Danville tuned
  #7
Old 05-15-2019, 12:36 PM
2004LB7's Avatar
Default
See if your u joints are hitting. Not the same joint but you get the idea
__________________
  #8
Old 05-15-2019, 01:56 PM
frankenstien's Avatar
frankenstien frankenstien is offline
Default
maybe its an optical illusion, but in the beginning of that video it looks like the front part of the drive shaft is just flopping around in the carrier bearing?
around the 6-10 second range of the video
__________________
2005 ECSB LLY
Danville Tuned
S&S LBZ SS Cp3
5'' exhuast
Fass 150
Built Trans w/SC1058
Bumpers built by me
  #9
Old 05-15-2019, 02:01 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
that carrier needs a drop bracket. are the lift blocks tapered or flat? stock leaves?
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #10
Old 05-15-2019, 05:53 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Moved to Chassis/Suspension. Sounds like the guys have a plan....
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #11
Old 05-15-2019, 10:14 PM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Default
Marks on the converter are from some lazy ass using a screwdriver to pry the engine over instead of doing it the right way.
__________________
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet narrowed journal crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and Billet S480 over a DTS 67.7
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #12
Old 05-16-2019, 06:39 AM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
Quote:
Nothing wrong with turning it with a screw driver.
__________________
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #13
Old 05-16-2019, 06:24 PM
gmc502 gmc502 is offline
Default
how close is the exhaust hanger to the rear driveshaft,,looks like there is a band on the shaft.
__________________
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
