Old 05-10-2016, 09:20 PM
doug9940's Avatar
doug9940 doug9940 is offline
Ca LLY
Default SERVICE AIR BAG message won't turn off
The DIC shows "SERVICE AIR BAG" message. Also has a red warning light on, little red light that looks like a steering wheel with a deployed air bag. I just bought and replaced the impact sensor with a new Doorman sensor (part # 590-204) thinking that would solve the problem. Nothing changed, still have the warning light and the message. Truck is same as my signature. Anyone have any other ideas?
2005 Sierra CCSB 2-WD
Mike L stage IV w/Precision ML convertor & Mike L trans cooler, Suncoast 6speed conversion
S&B Filter & Intake, AFE Bladerunner mouth piece (extrude honed) Garrett GT4094VA (w/Danville billet compressor wheel, extrude honed compressor housing & exhaust housing, jet hot coated exhaust housing), Banks Technicooler w/ 3" tubes, Wherli Fabrication custom 3" LBZ Y-Bridge, LBZ manifolds, RDL Pro-Flo Log style headers and up-pipes (jet hot coated and wrapped), Diamond Eye Down Pipe (jet hot coated and wrapped), 4" turbo back exhaust, EGR deleted, PCV rerouted
PPE Billet Fuel Pick-up, Airdog I 150 lift pump, Wicked Diesels stage III CP3, PPE race valve, PPE ported rail fittings, Exergy 60% over injectors
So Cal Diesel Stage 1 heads, So Cal #3388 camshaft, Carillo Rods, So Cal .020 over cast pistons, So Cal billet flywheel, ATI Damper, ARP head studs, main studs & flywheel bolts, Merchant H2O pump & Motor Mounts
EFI Live (tuned by Tony @ Ridge Runner Diesel....Moonshine)
677 HP 1032 TQ
Old 05-10-2016, 09:23 PM
DefiantArms's Avatar
DefiantArms DefiantArms is offline
Limp Mode Cowboy
Mines been on for a little over two years just haven't messed with it. I was going to replace the sensor Bc that seems to be the common fix. Good luck wish I could help more. -John
John
2005 Chevy 2500 LLY CCSB "Nyx"
Legal Disclaimer: My comments on this board are based on my personal experiences and life lessons. Don't try this at home. Your mileage may vary. Model shown includes options. Past performance does not reflect actual capability or intelligence. I'm off my meds. Don't listen to a thing I say, you've been warned
Old 05-10-2016, 09:27 PM
doug9940's Avatar
Ca LLY
Thanks John. I can tell you that replacing the sensor was a piece of cake. Hardest part was disconnecting both batteries. Whole job only took maybe 15-20 minutes. Just wish that was the solution.
677 HP 1032 TQ
Old 05-10-2016, 09:28 PM
RPM Motorsports's Avatar
smokinum
Clock spring behind the air bag, very common
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
Limp Mode Cowboy
Yea I went to local junk yard and got a hand full of them off trucks they had there but we're all wrong year and didn't match up
John
Old 05-10-2016, 09:29 PM
doug9940's Avatar
Ca LLY
Does the spring break or dislodge or fatigue or what happens to it and what is the fix? Is it a dealer only item or can I get one from an auto parts store?
677 HP 1032 TQ
Old 05-10-2016, 09:34 PM
Limp Mode Cowboy
Seems like a good time for me to go ahead and upgrade to a steering wheel with controls
John
Old 05-10-2016, 10:11 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Be prepared to replace the airbag module too. The impact was recorded and the airbag was deployed. This event will eather need to be cleared (some internet searchs will turn up a few places that will do it) or the module will need to be replaced. I dont recall if the vin needs to be programmed into the new module.
2008 Chevrolet 3500HD DRW LTZ
  #9
Old 05-10-2016, 10:14 PM
doug9940's Avatar
Ca LLY
No impact ever occurred. Truck has never been in an accident.
677 HP 1032 TQ
  #10
Old 05-10-2016, 10:24 PM
Limp Mode Cowboy
Me either well except a few of those concrete poles infront of the gas station on Friday nights
John
  #11
Old 05-10-2016, 11:24 PM
2004LB7's Avatar
Sorry. My bad. Thought i read you replaced the airbag
  #12
Old 05-11-2016, 07:28 PM
chevyburnout1's Avatar
chevyburnout1 chevyburnout1 is offline
Fixing it till it breaks
Run by the dealer. Be stubborn and say you don't want any diagnostics, just the air bag code pulled. The few dealers I've been to (and worked at) would do that just to make a customer happy. A code number will help us out greatly. Can be an inflator module, driver or passenger, connector problems, or wiring problems.
Dustin
'03 Silverado LB7
GT3788/CT6x88mm compounds _ 60's _ duals _ fingers _ 6480af
'77 K-10
52"/56" front/rear leaf springs and rear shackle flip: 8" lift total _ D60/14blt 4:56s _ 40" Swamper IROK's _ 383 w/nitrous _ SM465 _ 208tcase
'97 Cadillac Deville
Morimoto Mini 5000k projector headlight conversion _ 500watts in the trunk _ 20's _ Flowmasters _ Tuned ECM _ Rear mount turbo in the works....
  #13
Old 05-11-2016, 08:23 PM
Molly Molly is offline
i can't seem to find
Mine has been turning on when it's below 70* or if the truck sat all night for 2 years lol. I just hit the enter button on the steering wheel. Been trying to make my self stop by the dealership and get a code though.
Sent from your girls iPhone.
07 CCSB
PPEI tunning / 45% tips / FASS 150 / Suncoast 1058 Converter / Limitless Diesel built trans / Deleted/Rerouted/Shimmed
Rare Parts / 3" drop / 3" MBRP downpipe / 4" MBRP exhaust / 7" SoFlo Stack / 20x10 Fuel Couplers / 305 50 20 Nitto 420S
