  #46
Old 07-17-2018, 05:57 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
You nailed it Dale. Those not wanting a tune is going to be key...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
  #47
Old 07-18-2018, 06:30 AM
LBZ's Avatar
LBZ LBZ is offline
I currently fit this category but I have warranty still so itís not realistic for me to do it yet. But I know a few guys that would be interested in doing this to save their own dime in trucks they have no interest in deleting or tuning.
  #48
Old 07-18-2018, 06:41 AM
I currently am in that group as well. I like my truck quiet and smooth...
  #49
Old 07-18-2018, 11:58 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
From looking at the pump I have that doesn't have a gear pump on the rear it seems there are two practical locations to tap on the body.
One, just under and to left of the relief valve and the other at the bottom of the pump. Not sure if any of those could be utilized within the confines of the engine bay
2008 Chevrolet 3500HD DRW LTZ
  #50
Old 07-18-2018, 12:10 PM
2004LB7's Avatar
Maybe a third location between the other two. This on would angle the fitting but might allow for more clearance if needed. This area if probably 3/8-1/2" thick so more material for threads. The other locations are maybe 1/4" thick
  #51
Old 07-18-2018, 12:28 PM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
Give us a bit and I believe we can make this work without drilling the pump or removing the pump.
Sent from my SM-G930V using Tapatalk
2015 Denali CC/SB LML
2013 RC/LB LML
2006 RC/LB LBZ, SXE472/87/1.0 & FI491/100/1.45, 250% F1 Injectors, Dual 10mm CP3, SoCal Built Engine, JoshH Built Trans, JoshH Tuning. 10.18 @ 140mph and still going...
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
  #52
Old 07-18-2018, 01:53 PM
2004LB7's Avatar
It would be a pinch if you just used an axillary pump like VW. Just tap of the fuel feed line, through the axillary pump, filter then to the FCA bypass
  #53
Old 08-26-2018, 07:56 PM
CDmax16's Avatar
CDmax16 CDmax16 is offline
FNG
I am curious if there is any update on this bypass kit?
I have the Exergy MPROP installed now but would feel more comfortable with this kit.
2016 2500hd Custom Sport, Z71, LTZ
Moto 961's and Nitto Ridge Grappler 295/70/18
Amp steps, Weathertech mats, Extang Encore
S&B dry, Edge Insight, AirDog II 165, MotorOps
MBRP down pipe, Recon led tail lights
Kryptonite ucaís, tie rod sleeves, pisk, sway bar links CCM diff drop, Fox shocks, CalTrac traction bars, Airlift bags, Wehrli intake bridge, AFE intercooler piping,
Nitro 4.30ís
  #54
Old 08-26-2018, 08:17 PM
coker6365's Avatar
Version 2 has been on and running for a couple of weeks now on my 2013. Functions without a lift pump for use on a bone stock pickup but a lift pump is recommended to get the most value. We will be making a few adjustments to the mounting and hose routing before releasing.
2013 RC/LB LML
  #55
Old 08-26-2018, 09:32 PM
CDmax16's Avatar
FNG
Sweet, as soon as they are ready, I will take one.
Nitro 4.30ís
  #56
Old 10-22-2018, 10:15 PM
matty169 matty169 is offline
FNG
Me too..........or I will be doing the CP3 conversion.
  #57
Old 11-10-2018, 07:41 AM
SheeB SheeB is offline
Gearhead
Saw mention of this thread on another forum so I'm listening in.
  #58
Old 11-16-2018, 02:52 PM
kwale86 kwale86 is offline
FNG
Same here. I am in the process of rebuilding my truck after a collision. I currently have the cab off the frame so engine access is very easy at this point. I'm holding off on doing the CP3 conversion but would like to try this approach if it is available before my truck goes back together.
  #59
Old 11-17-2018, 07:59 AM
JoshH's Avatar
JoshH JoshH is offline
I have seen the prototype in action. I know Richard is busy with his full time job, but he is still working on getting a fully tested product to market.
06 Silverado 4x4 CC/SB
  #60
Old 01-20-2019, 08:45 AM
gmc502 gmc502 is offline
any updates on this?My truck has 83k and I'm a little nervous.should I be looking at a lift pump now?
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
