  #1
Old 10-09-2018, 08:43 PM
Henry95's Avatar
Henry95 Henry95 is offline
Default Traction bar questions
What bushings are you guys using when you build your own ladder bar/ traction bars.
  #2
Old 10-09-2018, 08:53 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Quote:
Spring eye bushings from a 80s Chevy 1.5”. Autozone
__________________
03 reg cab. Low and slow
07 crew long classic- stolen
  #3
Old 10-10-2018, 05:39 AM
Henry95's Avatar
Default
Quote:
Thanks. Are you using DOM or regular pipe? 1/4inch?
  #4
Old 10-10-2018, 07:51 AM
clrussell's Avatar
pro-procrastinator
Default
I’ve used both. Last set I built for myself were chromoly .250 wall.
__________________
  #5
Old 10-10-2018, 08:24 AM
Henry95's Avatar
Default
Ladder style?
Thanks for the info.
  #6
Old 10-10-2018, 09:43 AM
clrussell's Avatar
pro-procrastinator
Default
Ladder style?
Yep. 60” bars
__________________
  #7
Old 10-10-2018, 10:08 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
if you use chromoly, 1.75" OD .120 wall is plenty. If you want to use DOM (would not used HREW), you need to use .250 wall in 1.75 or larger OD.
i wouldnt go much below 1.75" if you sled pull BUT i have yet to hear of the 1.5" .120 wall chromoly ones i built guys years ago ever bending. DOM is much weaker than chromoly, thus needs the .250 wall min but damn will they be heavy. I warned a few people about going thinner than that on DOM and they found out the hard way when it tacoed. .188 wall would work on a street/strip truck but i wouldnt use it on a sled puller.
personally, for the few bucks more and half the weight, id go chromoly .120 1.75" stuff.
bushings you can get at ruffstuff, ballistic fab, daves 4x4, polyperformance and a bunch of other places. make sure the bushing sleeve is .250 wall and id run a 9/16" bolt at min. dont go delrin, it will not flex and you need flex.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #8
Old 10-10-2018, 10:52 AM
malibu795's Avatar
malibu795 malibu795 is offline
Default
One end needs to flex
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #9
Old 10-10-2018, 04:21 PM
Henry95's Avatar
Default
Quote:
What do you mean. I plan on building ladder style. 2 points on rear diff one on frame. All points of contact to have bushings.
  #10
Old 10-10-2018, 04:47 PM
malibu795's Avatar
Default
Only one end need to be able to articulate for axle moment
Like so... principle wise..
__________________
Adam
  #11
Old 10-10-2018, 06:04 PM
Chevy1925's Avatar
Default
Ooohhh you HAVE to have some sort or shackle or slider in place at the frame mount then. That’s a triangulated axle wrap bar that you are talking about. Just bushing or joints won’t be enough and it will cause a real crappy ride as well as a ton of bind if no shackle or slip is in place
__________________
James
  #12
Old 10-10-2018, 06:50 PM
malibu795's Avatar
Default
If it's a pavement princess it doesn't matter
__________________
Adam
  #13
Old 10-10-2018, 07:24 PM
Chevy1925's Avatar
Default
If he likes his back it will lmao
__________________
James
  #14
Old 10-10-2018, 07:31 PM
Henry95's Avatar
Quote:
Never seen one with a shackle. If it’s a single bar. One contact on each end it isn’t a ladder style. And would still be relying on the leaf to act as the upper control. Wouldn’t having the shackle defeat the purpose? It would have to be done as to have constant tension or you’d still get wrap till everything hit limit.
If it will ride like shit with that I am just gonna build a normal straight trac bar. Just heavier then what I was planning.
  #15
Old 10-10-2018, 07:33 PM
Henry95's Avatar
Default
With one end being a hiem wouldn’t it cause wear a lot quicker and you’d feel it more then a rubber bushing?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
