  #46
Old 05-13-2018, 07:04 PM
t.watts1340's Avatar
t.watts1340 t.watts1340 is offline
FNG
Default
Took the truck on its maiden voyage, down to savannah and back. Little over a 400 mile round trip. Got the ac working before we left, I had to jump out the low pressure switch to get the Freon to take.
Only had a little hiccup on the way back, stopped at a gas station to re fuel (getting around 15 mpg right now) and went to start the truck up and it lost its prime.
Not sure if itís related or not but cruising around 70-75 every 15-20 minutes the truck would make a noise, nothing crazy but definitely noticeable. Sounded similar to the noise bigger tires make on the interstate. Or like a sport bike was coming up from a ways back. Maybe something with the cp3? A little concerned about it.
Got a new clock spring coming in the mail this week, gonna get to the bottom of the 4wd issue as well. New tires and fix the hydroboost and I think Iíll be set.
Iíll post more pics of the truck when I get a chance, first diesel truck and Iím hooked. This thing rules.
  #47
Old 05-15-2018, 06:01 PM
FNG
Default
More dumb questions.... could this roaring noise come from the fan? It comes on intermittently cruising the same speed. Not sure how these fans work.
Thinking about doing a lift pump, worried on why the truck lost its prime when I stopped for gas. Any suggestions? Iíll be doing some more research before I pull the trigger on a kit. Donít plan on pushing any crazy HP or anything just want something to help with longevity. Thanks!
  #48
Old 05-15-2018, 06:11 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Yes the fan will come and go as needed. Itís a thermal clutch and does itís own thing as heat related.
Lift pump is a great idea. Just check your filter head and maybe rebuild it if it needs it. Generally a leak will show up if you push air into the filler neck
__________________
03 reg cab. Low and slow
07 crew long classic- stolen
  #49
Old 05-15-2018, 07:18 PM
FNG
Default
After a few hours of research I think Iím gonna go with an AirDog 2 100gph pump. Itís overwhelming how many threads there are on the subjects of lift pumps....
Can anyone else notice their engine fan engaging? I didnít imagine it would be as loud as it is, I did put a new fan blade on though.
  #50
Old 05-15-2018, 08:06 PM
clrussell's Avatar
pro-procrastinator
Default
Yes they are loud when engaged.
Full lockup at high rpm sounds like a train is about to run you over
__________________
  #51
Old 05-15-2018, 08:19 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
Fans are real loud, but so is the power steering pump when the fluid is boiling, check the harness for the four wheel drive going to the actuator, might have got mashed by the motor, if not actuator is prolly junk or transfer sensor is out, the fan clutch shouldnít come on unless your towing heavy or it has a lower temp Hayden clutch.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles. Piston eater.
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #52
Old 05-16-2018, 03:48 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Filter head probably has a leak, very common, that's where I'd start with loosing prime. They are cheap to rebuild...
__________________
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc... <<<<Broken Under Construction : BTR boost cam, sodium valves, titanium springs, 15% overdriven balancer, 80lb squirters>>>>
1969 MGB GT MKII Factory Condition
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #53
Old 05-16-2018, 08:29 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
Kennedy pumps all the way man silent and easy to install.
__________________
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. Fixed and driving again
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
