Coolant loss into oil and no external leak! Help
Mass
May 17, 2026
Over sea’s
I’m working on a lbz CCLB with almost 300K
It has coolant loss with no external leak there is coolant in the oil when I go to drain it, the coolant pressure is getting into motor.
I cleaned the oil and took the truck for a drive and there was no white smoke out of exhaust and glow plugs are not rusty (the truck was sitting for a year) and look normal, so I don’t think it’s a blown head.
How else can coolant get into oil?? But no oil in coolant??
What other diagnostics steps to take?
Thank you !
3,581
x2 -- probably the oil cooler. These engines are 20+ years old now.
My experience, water pump usually doesnt leak inward, just coolant thru weephole.
Be safe over there.
3,795
422
If the oil cooler is leaking, I would expect to see mixing both directions. When the engine is running, oil pressure is 15-60 PSI and coolant is 15 PSI, so you would get oil in the coolant. But when the truck is shut off, oil goes to 0 PSI but coolant stays at 15 PSI for a while, and will put coolant in the oil.
