Cant build a 10 speed to be reliable at that power. They will need to be rebuilt frequently depending on your right foot and towing. I’d like to say i dont abuse my truck too but its very hard to keep my foot out of it and ive had my 02 for 18 years. A full billet vb, tcm tuning, upgraded clutches and a better converter will help but it still wont fix the E clutch issue
To get 625, you can do it on a modded stock turbo and large tune. It would be better on your pistons to run a much larger injector (60-100%) and a 10mm or 12mm cp3. Your intank pump will support that just fine
You can do a far larger turbo like a 469 or 472 and it will still spool extremely fast at 1500rpm due the high flow heads you have. A cam makes a huge difference too. You can go well over 625 but your trans will hate life.
The 10 speed was a big let down… i have a 2020 that was going to get compounds, injectors, and so on back in 2020 but after mike l showed me the lack of space to get more clutches in the needed areas, we both realized it wont last under high torque
