project " shoe string budget"
kenp313
Feb 14, 2016
92
I know there are plenty of build threads on here already but I would like to share my story
I purchased my truck about two years ago and with in months of having it, it started blowing white smoke at startup in the morning and after driving it hard. I thought it was excess fuel from Stat up when left on a high tune (that was an ignorant ass diagnosis). I later took it to a shop after noticing I was loosing coolant. The the shop diagnosed it as being a lifted cup and bad injectors. I diced with all the money that is being spent to fix the cups that I wanted to make sure it never happened again. The shop and I decided it was best to send the heads out to industrial injection to have a set of torque lock injector cups installed. So I gave the shop a hand full of cash ($7500) and dropped off my truck.
The truck was at the shop for 8 months. When it was time to finally get it back I got a call saying that it wasn't blowing white any more.......but the turbo was bad and I needed a new one. I decide while it was being done I would go aftermarket. I went with a fleece cheetah (awesome turbo and amazing sound). The truck was finally ready to pick up.
I drove my happy as 3+ hours to the shop to pick it up. Shop was closed so I got the keys out of fuel door (I believe) and started it up.BOOM.....what do I see......white f@$!ING smoke. So I drove it home and kept driving it around until a week later I seen coolant leaking out of the passage side exhaust manifold
I decide to disassemble the passage side of the engine and diagnose the problem. I took the p/s head to the machine shop and have it pressure tested. SH!t....it's cracked. Sooooooooo I never needed to spend 1800 for torque lock cups. After I found the bad news I order a new head and call industrial and had them send me a tap and install tool because I was going to put the new cups in myself.
After getting together the money for all the parts (mentioned above) I fixed er up and drove er to KY for vacation....(no more white smoke).. . I stopped at a fuel station and seen that the bottom of my truck was covered in oil and I had some blow by. When I returned from KY I though I may not have tightened up a hold down or a banjo so I tore the passage side down again. Got the money for the parts and got it fixed. And BAM..... sill smoking g out vent tube and leaking oil......... I got on the forum and someone suggested a compression test. I went out and purchased a compression tester and checked the cyls. The all had from 300-310. In my furious state of mind I decide to pull my truck into my (less than 1 car ) garage and tear that sob out of the truck.
I inspected the parts that I pulled off and noticed several cracked pistons. Not terribly cracked but they were still cracked . I took my engine to S&W Performance machine where I found out that my cyls were all oval. Sooooooooo I had them bore the cyls, grind the crank and cam, deck the block, and install cam bearings. I ordered all of my rebuild parts from HENRY @ CREATURES OF THE NIGHT PERFORMANCE..... that was an excellent experience very easy and all my dumb questions were answered by Henry.
I am now in the process of my SHOE STRING BUDGET REBUILD. I am doing this on a 4k budget and quickly burned threw the budget I will be sharing my pictures and experience through the build. Feels like I texted my life story on this damn phone.
kenp313
Feb 14, 2016
92
SPECIAL THANKS TO THE FOLLOWING
BRANDON- HELPED PULL THE ENGINE
WILSON - OWNER OF S&W PERFORMANCE MACHINE
HENRY-COTNP (ANSWERED ALL MY IGNORANT QUESTIONS AND HAD GREAT DEALS ON MY REBUILD PARTS)
HIPP11B:hug: -HELPING ME WITH ENGINE BUILD PROCESS
FORM MEMBERS- ANSWERING QUESTIONS AND GIVING ADVICE
CentolaCCSB
It will probably break
Nov 2, 2015
322
Mass
So since you started having problems how much money do you have into it with parts and labor? Just curious
kenp313
Feb 14, 2016
92
I purchased the truck for 16k
Injectors torque lock cups from industrial, 8in stack& labor=$7500
New fleece turbo, mbrp down pipe and overnight shipping est $3k
Misc gaskets trying to solve problem (multiple head gaskets and all gaskets involved several times $800
New head $500 presure test old $100
Tool and tap from industrial $275
Block crank and cam machine work $1035
Lbz rods new pistons with rings pins clips, all bearings, master hasket set, arp flex plate bolts $2300
Too damn much and i only put 6k on the truck since i owned it.
kenp313
Feb 14, 2016
92
I know having all of that done sounds nauseating!!
Its sickening and absolutly disheartining. Im 24 and not made of money. I just feel like i cant give up because im so far in. That would be like going all in then folding
3,421
Thats not a shoestring. More like a nylon rope.
Why did you think you needed the screw-in cups on a stock engine?
kenp313
Feb 14, 2016
92
I did the cups in the beginning when i was blowing white smoke. The shop suggested that would be a perminant fix.
As far as the shoe string goes. I have a 4k budget to rebuild this year. The majority of the things listed are from the 2 previous years
hipp11B
Apr 1, 2015
252
Georgia
I was happy to help brotha, can't wait to get it finished and back on the road, you deserve it man!
Lbz, built trans, efi by Danville, Danville 68, full egr delete, mbrp down pipe, 5" mbrp to 7" stack, ppe guages, custom traction bars, airdog2 165, ppe fuel rail mods, s&b, afe blade runner, Arp head studs..died March 2015
Parts collected for the build. SoCal super damper, SoCal billet flex plate, SDP S400 kit, II 85% CP3, PPE manifolds/up pipes, PCV reroute. Slowly but surely lol
kenp313
Feb 14, 2016
92
todays progress
Today's progress me and hipp11b
hipp11B
Apr 1, 2015
252
Georgia
AJH
257
Memphis TN
What shop did you have work on your truck? You gave them $7500, they had the truck for 8 months and they didn't fix anything. Did they crack the head? :confused:
kenp313
Feb 14, 2016
92
I'm guessing the head was already cracked
Sent from my SAMSUNG-SM-N910A using Tapatalk
kenp313
Feb 14, 2016
92
It was cracked in the exhaust valve I'm just putting 2 &2 together. Blowing white sweet exhaust. Replace cups problem persists. Replace head and install cups - no more coolant in combustion chamber
kenp313
Feb 14, 2016
92
The worst part is that it didn't cost them a dime
kenp313
Feb 14, 2016
92
Today me and hipp11b installed Mahale 20 over pistons, lbz rods, and arp rod bolts. We would have got done more but 2 a$$ holes forgot to put the lifters in before they installed one of the heads and did 3 passes on the studs. Glad we found it b4 we got much further
3,421
Eh, shit happens. At least you caught it that soon. It just cost you time.
Building one of these engines is actually pretty fun. Sure is educational.
