Anyone have the part # for an LML dipstick tube?
Where did you move the gpcm to? Also curious as to why you went with a drivers side? My pass side fit with profab manifolds and up pipes wrapped in levi's blankets and a 3" downpipe wrapped I'm heat wrap. Well I guess I had to bend it back a smidgeI don't have a part # handy but I ordered on for a 2014 2500HD lml off amazon and then I measured my old one and took off the difference off the top of the new one
On my lb7 I had to move the gpcm but the new location is so much better.
I'll get it tomorrow. Mine is in the garage and should still have the p/n on it. Got the stick too.
Well hell I like that alot more than the spot it's in now.This is where some move them to on an LBZ.
It moved back maybe 1/2" I'd guess maybe a whole 1/16 of fluid level change if thatKeep in mind when bending any dipstick tube or pipe you be lengthening the pipe "per se" thus when you bring the fluid up to the existing mark you will have too much fluid...
Fack forgot to check the numbers before I left for work. If you aren't in a hurry I'll get it to you when I get home in a few days.Thank you
HSP sells drivers side dipsticks for $115...
The oem lml driver side dipstick was $14 dollars off amazon free 2 day prime shipping from amazon. It was for a 2014 Chevy 3500.
I want to say no offence but I'm not going to. All those companies that sell those dipsticks for 100+ are straight up ripping people off.
The lml requires shortening, correct?
