adding Trac bar with drop shackles?
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
I was wondering if anyone has added a Trac bar to the rear end after adding super long drop shackles to there trucks. My brother has drop shackles and he left work one day and kicked it all sideways, and it looked like the rear end had some side to side play for sure. I didn't notice any sway when I added mine. It was just mainly a thought I had, I could see the longer shackles adding a little sway to the rear but maybe I'm totally wrong. But i don't think a Trac bar could really hurt unless your talking about weight. Just looking to hear a few opinions.
rickettzusaf
Nov 30, 2011
276
Goldsboro, NC
I had a 5 inch drop in the rear with my truck (2" drop hangers and 3" drop shackles) and I had custom made 55" traction bars. Basically they attached under my u-bolts and were welded on the frame right before it curved up for the rear. I also had full leaf still.
picture.php
bfmine
Sep 11, 2011
148
Cape cod,ma
Sounds like the op is talking about a trac bar to keep the rear end from moving side to side under the truck. Not the traction bar to fight axle wrap
zf>allison
Apr 30, 2013
3,394
elsberry mo
Yes a Panhard bar not traction bars. I have caltracs, and my truck seems stable. But i seen my brothers tire move side to side out of the wheel well pretty bad. He has no traction bars or anything. And we have the same shackles. If i didn't see what I seen it never would have crossed my mind. And that's him kicking it sideways not just cornering. Maybe I can get a go pro video of it doing it.
zf>allison
Apr 30, 2013
3,394
elsberry mo
picture.php
btw like that stance alot
zf>allison
Apr 30, 2013
3,394
elsberry mo
I was wondering if they would have the same effect. I'm sure it's gonna stiffen it up either way, Panhard or sway bar. I looked at hell wig sway bars but never pulled the trigger. I have a caltrac bar I ****ed up one bungs threads. I might cut it off and re weld a new bung on the one side and make it into a Panhard bar. But I'll gopro my brothers hangers before wasting my time. But I'm sure that's where the flex was happening.
zf>allison
Apr 30, 2013
3,394
elsberry mo
Just did a little reading. A pan hard seems to be used on leaf spring cars only when running rubber buschings in the leafs, which caltracs get rid of that with there aluminum ones. And on cars with long shackles/drop shackles. They also have alot less leaves so may not be as stiff as our trucks, but also most cars have rear anti roll bars where our trucks do not. I might build one just to do it. Might just be something fun to try out. If it doesn't work oh well. This would be geared more toward dd trucks that get driven hard around corners more than a drag truck and have drop shackles
zf>allison
Apr 30, 2013
3,394
elsberry mo
Yeah I might do one with heim joints. But those are cool for someone who can't make one. I wonder if they will work on lowered trucks?
LBZ1991
Nov 21, 2014
215
Winfield, MO
Still have the rubber in the rear and the poly in the shackle. But like you said your brother doesn't have cal tracs with the aluminum bushing up front
zf>allison
Apr 30, 2013
3,394
elsberry mo
Yeah that's why I wanna try a pan hard. My brothers reg cab already rides like shit. A sway bar would be horrible on top of it
bfmine
Sep 11, 2011
148
Cape cod,ma
I have a sway bar with heim joints on a jeep. Imo it's good to be able to flex with the suspension. But they wore out fast and make a lot of noise. The screeching from the heims go away with some lube. But the clunking doesn't. Fwiw. Good luck
Oct 16, 2008
951
21
Idaho
If you build one, I wouldn't do a double heim panhard. It'll wear out crazy fast. Make one side a rubber/poly bushing and it'll live a lot longer.
8,060
dont use the cheap ass heims and they will actually last a good long while. two 7/8" FK heims in the K or J series would work well. you will hear the bushings through the frame if you go anything but Derlin. Poly does not do well.
Oct 16, 2008
951
21
Idaho
My experience was a little different. 10K on my Dmax street rod last year and the double heim panhard was hammered out.QA1 heims. Going to a poly bushing this year to hopefully make it last.
