Let's see your engines
bartman432
Nov 4, 2011
242
It's not as flashy as some of the others, but it's clean
kjp800
Aug 6, 2008
525
New Jersey
heres mine
picture.php
picture.php
Looks real good, I like how you redid the AC lines.:thumb:
What did you do for a coolant tank? Dont see it in the pics
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
770johnny, what exactly has to be done with the ac lines? I have mpi twins and would like to run a hood stack but my lines and condenser is in the way. Just wondering what I have to do or where to get the parts. Thanks
770JOHNNYW
Sep 16, 2009
791
Gainesville ,Ga
its kinda complicated...its hard to find the correct size line or the same size o.d as the factory stuff so i went to a junkyard and got the rubber lines off 2 early 90's f-150's. then call up vintage air and get 1/2'' heater hose crimp fittings 90* and straight and you get the right size on both sides if your fitting. then just put it where you want it and tig it up i used all the factory alum lines just cut and reclocked:thumb:
85dura
Oct 28, 2012
Chevyburnout1- how did you paint the injector lines and fuel rail? i have everything painted on mine but i didnt wanna spray those and get paint in them? ( compressor and mini spray gun beinging used) thanks
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,374
9
Berthoud, CO
I just scuffed up the original coating on all the lines and rails, taped up the fittings, and threw a few layers of primer and paint on the lines. It lasted about a year. I wouldn't recommend it. I think I put too many layers on truthfully. Should have just scuffed it up and threw one or two layers of paint on and called it good.
Just redid them last month. Powdercoated everything. Definitely the way to go. But then bent a connecting rod. Going to powdercoat the valve covers and compressor housing of the turbo once I get everything rebuilt.
