Lonnie, do you care to elaborate any on the setting up of the 82 GM pedal for the tps sensors et al? Pics?
As always, awesome job!
C-ya
C-ya
Had a little scare... started welding the extension on the center shaft & the welder immediately sounded wierd & then a loud pop from the steering column.
I had the column grounded, but not the center shaft itself. As far as I can tell, the current through the column internals ignited the grease in the swivel portion. I at first thought I popped the airbag.....
