I'm right in the middle of some work stuff I have to get done. I'll look for the new pics a little later though. It now resides where the pass battery was![]()
are there any trucks that have reloacted the FICM that drive more then 1/4 mile or 300 ft and then get on a trailer and sit? id love to do this but i DD my truck so i dont want it to fail while 500 miles from home.
is there any special wire needed when you lengthen them?
From what I can see, the wire is standard copper wire
I know Sphinney DD's his truck. Just do the math, If fuel temps get up to 140* on an 80* degree day the coolest the the FICM will ever get is 140*. Remove the 140* fuel and now you have the possibility of reaching ambient temps. I am going to run mine dry but before the pulls I will fill the FICM with either washer fluid or cold water and drain it after the pull.
Last year, when my truck still seen road time, i could lay my hand on my FICM, that was relocated, but dry, right after a 45 minute drive on the way home from making several 11 or 10 second passes at the track. Can any of you guys with fuel going through them? Oh wait, let me guess... theres a reason its like that from the factory, right MikeS?:rofl:
From what ive read, fuel and underhood temps get a lot hotter idling than they do driving, so imo a pulling truck, that has a lot of idling around time in the pits, would get hotter than a truck driven on the highway everyday.
When I first disconected the fuel from the ficm I rigged up a 4 quart canister and circulated fuel seperatly. Thru my ficm. IMO waste of time I'd did npt make any difference on a race truck
and I'm am somewhat curious as to peole that think a ficm can not handle 20 psi? Why is it that u think that?
