Finally got time to throw the old girl on the rack. Went over her top to bottom and to make the race I’ll need to:
Make an adapter for the Anderson 5th wheel hitch
Clean air filter
Oil change
Rear differential oil changed
Fuel filters
Tcase oil change
2 cv axles (boots are torn)
Couple seals for the tcase
Fan for my fuel cooler
Overloads for my leafs
possibly an a/c compressor, it’s leaking out the nose of it
Get the Interior aftermarket gauges working and install a new egt gauge
New pads and rotors on front
While it was on the rack, I greased it all up, zip tied up some parts, added 1/4” more preload to the coilovers to get ride height back up, scraped the flaking frame coating off and hit it with some flat black, topped nitrogen off in coilovers, pulled the underhood insulation off (it’s ragged, need to find some new stuff) and cleaned up the lift kit drop brackets, steering drag link and tie rods, coilovers, UCA, axle wrap bars, drive shaft, the 483 compressor cover, intercooler tubes and the dual fueler wheel.
No pics sadly. Really didn’t look like I did much.
That will get me started and knock a good chunk out of “to-do’s”. Then it’s on to interior parts and bumpers
Clean air filter
Oil change
Fuel filters
Tcase oil change
