serpentine belt comes off
brown bear
como estan beeches!!
Mar 31, 2009
199
Durango CO
so i notice that almost every time the my truck hits the 100's mph the serpentine belt comes off i was wordering why is that and also if theres anything i can do to avoid that (besides slowing down) :hug: its just getting expensive everytime have to spent about 50 bucks on a new belt from napa thank you
brown bear
Mar 31, 2009
199
Durango CO
gotcha ill do that hopefully wont get this problem again or for at least for another 100k milles lol thank you guys
Vrabel
TOYAHOLIC
May 22, 2008
3,434
58
Hewitt, NJ
X2 on tensioner, get one from dealer. I remember when I got mine,it was actually a few bucks cheaper than parts store. imagine that.
3,586
X5 its the tensioner. I lost my belt at the end of a run last year. Its no fun losing brakes/steering at 90mph. :eek: Thank God I carried a spare belt, other wise I wouldnt have gotten home. Id replace the two idler pulleys at the same time. Good insurance.
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
METRO DETROIT
I am at my whits end with my truck too!:( i have replaced the idler pulleys, tensioner and tensioner pulley. My belt is getting torn up too often, the belt jumps over after a hard run and over 4000 rpm 100+mph. My buddy says he had the same problem and he remedied it with a better bearing, i will find out soon and let you know whats happening
MaxPowerLB7
Amateur
Nov 8, 2007
623
41
Spanish Fork, UT
I've been in the same situation. Replaced tensioner first(with aftermarket tensioner) didn't fix it. Replaced both idlers, didn't fix it. Replaced alternator, cause the bearings felt like the were starting to bind, didn't fix it. Like seven belts later I purchased another tensioner from the dealership(knowing that it wouldn't fix the problem) and have never had a problem since!
3,586
Vaz, use a straightedge and check your pulley alignment, esp the powersteering pulley. Thats probably whats going on in your case.
steakman
Diesel Nut...
Aug 31, 2009
69
Barrie, Ontario
at ~144,000 miles...I'm thinking it's time to do mine. May as well do the tensioners at the same time. Given the info here...I will for sure use OEM parts.
thanx,
Theo
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
METRO DETROIT
i got the better bearing pressed into my factory pulley, so far so good for like 3 weeks now, no more belt jumping:happy2:
Bobza57
Dec 22, 2009
Carmel, NY
Is the idler pulley on the tensioner for My 03 2500 HD Duramax a separate part??:(....The dealer says I have to purchase a new tensioner with pulley for $107.51
3,795
422
I couldn't get just the pulley on the tensioner from the dealer. I took the pulley off and brought it into a couple parts houses, and one of them was able to find a match (I think it was Napa?). Cost me like $20 instead of 100+, and has been working for over 10k miles.
onebadduramax
One Bad Duramax
Jul 28, 2009
30
mine keeps doing it replaced the pulleys alt belt 3 times and has a new idler pulley this happens when i really step on it
plus if i put a factory belt on it will quick like crazy and if i put the gatorback on no noise
Baking83
Apr 17, 2022
21
I can’t keep my belt on.
Built 7.1 stroker Lml dual fuel
Wagler tensioner tight as s***
