That’s pretty much on par with what I was stating.
If your stock turbo ain’t coming on to 20psi at 1500rpm and good throttle, she’s real shot, tune issue, boost leak or drive leak.
If you change the wheel on the stock turbo or upgrade the size, it lags worse than that 364. Russel (yellow Chevy) found that out when testing
It’s just the big turbo that’s the limiter. I easily made 800 on 480 over p/p ihi. 483 and 100 overs was a seat of the pants difference in power from before. Blake had track proven 950hp on his old truck with stock lly vgt and same 483 I had
we’ll see what this IHI and 83 will do. I want 1100 ?
I'll put the YouTube links to @coker6303 videos here, it's impressive how the setup runs.
Source: https://www.youtube.com/watch?v=_q6jUeQHP0k
Source: https://www.youtube.com/watch?v=d0r2J1l619A
Source: https://www.youtube.com/watch?v=JQQX-T4OX4o
Source: https://www.youtube.com/watch?v=xi9lQALPoQ4
Source: https://www.youtube.com/watch?v=P754EmFr_1A
I honestly don't know. Russell and I have talked about his 364.5/480 setup and he loved it.I may have missed it, I noticed he had tried the 64.5 and 66. Did he have a preference between the two chargers? This is the exact route I want to go on my lb7.
I have a lb7 Intune with a ihi and a 480. Customer loves it. Ties well makes good power too. He has 100 overs in it.
Id rebuild the IHI with a Wetzel wheel, p-n-p it and add the larger to it.
Being where you are with it I would go with the turbos you are talking about. As long as your convertor is right for the setup you will be very happy with it.
It trying to high jack your thread here but I’m kind of on the same topic as you. I have a lmm with a Danville 63.5 in it right now. When going up some hills it tends to drop down into 5th when towing a decent load. If I added a 475 on top of the Danville would that help me stay in 6th?
