CCSB 4x4 Wheelie Bars Needed.
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
I believe it was a 10.2 around 137mph. Definately 9's with a smooth run. The horsepower is there, no doubt.
coker6365
Dec 4, 2011
486
Hey guys thanks for the share, nothing broke just a little violent...need to get the suspension dialed in
Sent from my SM-G930W8 using Tapatalk
What air and fuel are you running if you dont mind sharing?
coker6365
Dec 4, 2011
486
2x10mm pumps, 250 overs both S&S Diesel Motorsport. 472/96 and 5533r with 94mm comp both FI
Nice. I am guessing it's gated around the 472 as well. Cleans up nice for the power it's making.
coker6365
Dec 4, 2011
486
No I'm getting before the 72 to atmosphere not to the 94
Gotcha. Hurry up and get that suspension dialed in so we can see it cut a 9! It's definately got the power to do it.
DieselmafiaLLY
Keep Calm and Go Crazy
Apr 6, 2013
1,102
Ontario, Canada
Ended up changing a bunch of the suspension setup, cut out trac bars and installed caltracs, removed pitman and idler braces, installed DHD front diff brace, center link brace, welded in some gussets, pulled the front diff + control arms and put poly bushings in everything ect. Tom at SDS was nice enough to offer his shop up to work in as I don't have one big enough to do that...planning to go to the track once we get some good weather
prostreeter600
Street rodder
Jul 18, 2010
893
Dallas Tx
Wow that’s a lot of changes for sure . Wish you the best of luck and can’t wait to see videos of your next runs . Hope it gets in the 9s with some good straight launches and runs . Are you doing anything to pin down the front suspension ?
