Do you have any or know where to get some Corbin?
Just talked to a guy. Suppose to fill up tomorrow. I will let you know corbin
I'd put the nozzle in the air intake in between the MAF sensor and the turbo for best results and spray the whole way. Start with a 50 jet and see what it gets you.:thumb:
Very short rods![]()
:spit::spit::spit::spit:
Spray her all the way for the win. You know the other guy is watching this thread!!!
The West plains mo. co-op is proud of this truck I bet.
It's the base diesel kit, I'll sloppy mechanic that b$%# with a drill bit of I have to. We will keep our eyes out for another one. I think this kit is meant to run with no jet? It doesn't come with one.You will need to swap it. Get one with a .120 orifice or larger. We ran a .120 solenoid in Levi’s truck with a .105 jet (had to use one to seal the tip to the line) and it was good for 150-175hp with as much extra fuel he had
What you have seems extremely small for a solenoid though
Why not make a pass with the small hit and work your way up?if your having problems with traction the hit of a 200hp shot is going to make the truck go crazy. You might get what you need out of the small shot. You can always change the jet at the track.
Interesting shifter, Jesse. I bet it really grips your racing gloves?
Why did you guys run the A-pillar bars at that angle instead of up the pillar to the main hoop corner?
