Built motor sluggish
TheDirty06
Sep 28, 2014
115
Horton, KS
Ok I'm new to this built motor stuff so it might just be me. But my motor seems sluggish until it gets to 2200rpms then it's an animal. Like goin down the road 70mph I'm at 1500rpms and 3psi of boost so on a hill it just chugs and puffs smoke the egts are around 1300 up a hill and around a 1000 on the flats. I thought it was maybe a dirty maf sensor so I cleaned that and at idle it's 35gms at 70mph it's around 95gms. So I think my maf is fine. There's no boost leaks I've checked that with my boost leak testor. I'm stumped what's done to the truck is in my sig.
TheDirty06
Sep 28, 2014
115
Horton, KS
Nope I haven't done anything since I got it back from the engine builder. It's been like this the whole time. That's why I don't know if it's just me
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Did you swap cams? Did you drop compression? Did you change the fuel setup? Have you logged it?
TheDirty06
Sep 28, 2014
115
Horton, KS
Yea it's has a wagler stage 1 af cam, 16.5 to 1 pistons, the fuel is 100 overs and dual pumps. I data logged it Mark sent me new tunes and it didn't change besides the turbos spool better after 2200rpms
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Well throw my idea out the window. I'm sure if it is a tuning issue Mark will be able to get it squared away.
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
What torque converter due you have.
8,237
Turbo lag :roflmao:
Ha!!
I'll check again for boost leaks. How would you check a drive pressure leak or can you?
Look for soot on the firewall or around any connection point. I'd also pull the up pipes and look at the gaskets if I didn't see any obvious signs. If the gaskets have soot all the way out to the edges anywhere on them, that's a leak
