Freeze it when it's all together.
on getting the torque wrench
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Ok. I can do that. What does that do?
If he over tourqed the valve body… Then chances are it's warped. And he'll need a new valve body. Ask me how I know
The valve body is made out of a fairly soft metal. It's doubtful that you would be able to see the warping. But I've either half is warped then they don't mate together correctly and under pressure fluid will leak out of the passages its supposed to be in. But I'm not a transmission expert I'm just telling you from my own experience
From reading through these post i would definitely say at first you came off strongly demanding someone tell you what you did wrong. Then disrespectful when you didn't get answers saying people on the site are not experts and know nothing about the Allison. This is why you got all the attitude. I think like 4 post in you got good advise to unplug the trans to verify it's internal and not electrical.
From the info in the posts here i would say you should check the trans pressure first but other than that you need to remove it and take it apart to see the damage and any parts missing or installed improperly. If your unable to determine improperly installed parts or missing parts that is where you should be having someone that can do it. Otherwise you may have this trans in and out more than just one more time.
What people are frustrated about are things like you have a shop and don't really understand what a warped valvebody means or the concept behind putting it in the freezer to check for binding. Also ppl have told you why the trans needs to be repaired vertical but you decided to do it "the easy way" horizontal which should be a red flag to you once you hear that.. Sometimes you need to know why your doing something and not just do it to understand what's going on. That's not to sound like I'm picking on you just from your posts come off as someone needing to be spoon feed. You said you need to know what 2 dollar part out of 100 parts needs to be replaced but how could anyone know the extent of the damage without seeing the parts disassembled?
I think you will get more help once you have the trans all apart again.
Well the majority of the advice I was getting was to take it to someone else. I'm going to be spending my week tearing it back apart and inspecting it. Hopefully if I come across any questions, I'll be able to get some help. And just because I have a shop does not mean I know everything. Noone knows everything. But I have always done pretty much anything except major body work and transmissions. I wanted to change that and learn more about transmissions and saw an opportunity to do it to my own, rather than a customers. I saw several posts and videos of the rebuild being done horizontal on a work bench so I didn't think it was a problem until I was told about the bearing on here.
Heres a video that clearly shows it sitting horizontally being torn apart. And it's not the only one. There are a couple others I saw but this had the most detail throughout. I used it to help figure out which clips come out before which parts. It's easier for me to see an actual part than a description of it. https://youtu.be/wEGUAWGAOto
And thank you Dave for answering about the bearing noise and for wishing me luck. I should be able to start teardown and inspecting Wednesday. But I know to look for the valve body warping and a bearing destroying everything that's precious inside. I'm going to recheck the thickness of the clutches too in case they are burned up. I'll take pics of any damage I find
Those clutches aren't so bad LOL they have at least a half dozen more limps leftThere won't (likely) be much in the way of a thickness difference if clutches are new and burnt.
Here are some crispy clutches for your viewing pleasure:
If they have any dark spots, personally, I'd consider them done. I wouldn't put them back.
IF your current issues are related to you not properly torquing the VB down, there may be the possibility that any warpage caused by it isn't permanent, and proper torquing may fix that particular issue - but assuming for a second that it's not permanent (No guarantee), it's possible that the improper torquing of the VB could have roasted some clutches due to lack of proper pressure, and if one or more bearing fell out of place during assembly, you could have some much bigger issues than roasted clutches waiting for you.
I 'thumb my nose' at SOME torque specs - there are some that it's like 'eh, really good and tight is good enough', but head bolt (or stud) and VB bolts are two that I've dealt with (among some others) that should never be questioned and I'm super anal retentive about. If you don't have the proper torque wrench for the task, either get one or don't do it.
I hope that after this evolution, you learn from any mistakes, and have a properly functioning transmission upon re-assembly. Assembling an Allison isn't really rocket science, but there is a 'right way' and attention to detail is critical. One bearing installed backwards (for example) is an expensive mistake.
Make sure the torque converter is seated properly when you put it back in. I only skimmed through the post. If you need a valve body I have one that came out of an LLY. I well sell it for cheap.
I 'thumb my nose' at SOME torque specs - there are some that it's like 'eh, really good and tight is good enough', but head bolt (or stud) and VB bolts are two that I've dealt with (among some others) that should never be questioned and I'm super anal retentive about. I've never done a lower end rebuild, but I'd be just as 'Anal retentive' with caps and mains - some things 'eh' isn't good enough. If you don't have the proper torque wrench for the task, either get one or don't do it.
